Old 01-04-2020, 07:04 AM   #1
Towing dilemma
I can't believe I'm the only one who's had this problem so here goes. Our camper is a 25 foot Coachmen APEX tag-along. My tow vehicle is or was an F-150. Now I have a RAM 2500 and the receiver on it is several inches higher than on the F150. I need to tow the APEX to the dealership to trade it for the 5th wheel we plan on buying. Do I need to purchase a whole new receiver that sits lower in order to line it up better with the APEX? On the old truck we had weight distribution/sway bars. Will I be okay to just hook the old camper to the new truck? I don't even know if the 2 will come together. Do I need to bring the 2500 to the dealership so it can be re-fitted? Ideas please. Thanks.
Bill
Billus338063 is offline   Reply With Quote
Old 01-04-2020, 07:34 AM   #2
Not sure which WD you have but must have a long shank and you are able to adjust the height of the ball. You might even have to invert. I used my equalizer 4 pt on my 2011 Ram 2500, 2014 Tundra 2 wheel, 2014 F150 4x4 and 2016 F350 4x4.
If you canít do that then wal mart tractor supply or auto parts stores have one of these because itís a 7 inch drop it more expensive than the 2 or 4 inch drops. Click image for larger version
Also if you can hook up the truck might squat enough to make it towable
moose074 is offline   Reply With Quote
Old 01-04-2020, 08:00 AM   #3
Towing dilemma
Thanks Moose. If I go with what you show in your picture I'll have to tow without the WD. Attached is what I have.
Old 01-04-2020, 08:05 AM   #4
SlowrideHD's Avatar
You won't need the wd hitch for the trip to the dealer if you tow with the 2500.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 01-04-2020, 08:17 AM   #5
BigH's Avatar
Bill,
Check your trucks owner manual...2500hd's don't have the same wdh requirements that half tonners require. In the manual there will be info on the amount of weight that requires a wdh for your wheelbase.
My truck wouldn't require a wdh for your trailer but I wouldn't want to pull it nose high so I would do as previously suggested and run to the hardware store to buy a cheapy with the proper drop (and rating) to pull the trailer to the dealer.
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 01-04-2020, 08:24 AM   #6
Doesn't that hitch have the ability to lower the ball/mount by removing the bolts and moving the mount on the square shank?
If so just drop it as low as possible and tow it to the dealer without the bars.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 01-04-2020, 08:34 AM   #7
Towing dilemma
It looks like you have about 4 inches of drop that should help a lot itís the two bolts on the side. How far away is dealer if reasonable close you might make it. That said with impact gun or cheater bar hook up receiver to truck to help hold in place. Itís quick and easy. You might get lower inverting the head unit
Old 01-04-2020, 09:24 AM   #8
spicercars's Avatar
Borrow or buy a drop receiver and tow it to the dealership without the bars. You don't need them for a single trip with a 2500.
2020 Wolf Pack 23GOLD15
1998 Dodge Ram 3500 Cummins Diesel Dually
spicercars is offline   Reply With Quote
Old 01-04-2020, 09:43 AM   #9
If gonna use standard hitch for other trailers great ideal. If spending 10 minutes to drop hitch height. OP can save money doesnít have to use bars
Old 01-04-2020, 09:46 AM   #10
hack522's Avatar
When I tow mine locally, I use the WDH but no bars. It's only necessary for long distance highway use. Good luck.
hack522 is offline   Reply With Quote
Old 01-04-2020, 09:49 AM   #11
007matman's Avatar
The hitch looks like it's in the top position.
Just drop it down to the bottom.. don't worry about proper setup.. you only need the ball.
If you sell the hitch (which is what I'd recommend) seperately the next guy will need to set up up anyway. If it's not 100% level I wouldn't worry about it.. you're not towing far, correct? As long as the bumper doesn't drag you'll be fine.
007matman is offline   Reply With Quote
Old 01-04-2020, 10:29 AM   #12
spicercars's Avatar
That's why I said maybe borrow one. And yes no bars.
Old 01-04-2020, 10:38 AM   #13
Towing dilemma
Thanks everyone!
Old 01-04-2020, 10:40 AM   #14
hack522's Avatar
By the way, does your TV level automatically? Mine does which is why locally it isn't an issue.
Old 01-04-2020, 01:15 PM   #15
I wouldn't waste money on a new hitch, use what you have. Tow the trade-in to the dealer and get your new 5th wheel and be done with it. With that said, you haven't told us how far the dealer is from you, that always helps when asking for recommendations of this sort.
2016 T21TBHW
2017 Ram 2500 CTD CC SB 4x4
Ortep is offline   Reply With Quote
Old 01-05-2020, 08:36 AM   #16
My SIL tows a long TT toy hauler using a Ram 2500 SRW diesel. Uses a appropriate 2&1/4" drop hitch for leveling. Never uses a WDH. Me, I'd use a WDH but he has no problems. He routinely tows a 400 mile one way trip to a 4 wheeler event.
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 01-07-2020, 09:29 AM   #17
Grammar Pedant
67L48's Avatar
That.
Super easy and $0. Will take you 5 minutes to drop the head of that hitch to the lowest position on the shank. Done. Hitch and go. Don't worry about the WD components.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 01-12-2020, 09:22 AM   #18
yetavon's Avatar
Id drop your current WDH down and not worry about the bars.
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
towing
