01-23-2023, 03:29 PM
Towing on car dolly
Looking for advise and experience towing on a car dolly. Just moved to motor home from fifth wheel. I plan to tow a Ford TBird with the rear axle on the dolly. What recommendations for the best dolly, or does it matter, and will I need tail lights on the car or are the lights on the dolly all that is required? Thanks.
01-23-2023, 04:15 PM
Kanadian Kamper
What year of Tbird you talking?
I’m not sure of the rules for lighting a towed vehicle in ALL states, but if you value the Tbird at all……I’d make sure to light it. Afterall, the majority of the length of the Tbird will be hanging out well past the dolly lights.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
01-24-2023, 09:43 AM
go to harbor freight and get an inexpensive set of towing lights that are magnetic and place on the rear of the vehicle. I did this for years towing a full size pickup truck.
Retired Navy
2016 Flagstaff 26 FKWS
01-24-2023, 10:14 AM
Kanadian Kamper
SeaDog……
I know you know we know what you’re saying, however, the OP said he’d be towing the Tbird with the rear axle on the dolly, thereby, towing his Tbird backwards. So, if he placed the magnetic towing lights on the rear of his vehicle like you did on your pickup truck, his towing lights would be farther back from the tail end of his Tbird than the dolly lights.
Geesh. I think I confused myself trying to explain this.
Ken and Terry
01-24-2023, 10:21 AM
Ya I should have said "place them on the vehicle" sometimes I forget how careful you have to be when responding.
Retired Navy
01-24-2023, 10:35 AM
My concern with towing any car backwards is the difference in the length from the towing axle, in this case the rear axle, to the end of the car. Most cars are longer from the center of the rear axle to say the rear bumper than from the front axle to the front bumper. I'm thinking clearance from the rear of the Thunderbird to the rear of the MH on turns, , ,
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
01-24-2023, 10:49 AM
I'm wondering why this car needs to be towed backwards instead of front on the dolly or four down? Is it a problem with the transmission not getting lubrication? or is it not wanting to put tow miles on the car? just wondering
Retired Navy
01-24-2023, 03:34 PM
Worse than that
That's the second difficulty. The first one is getting the car on the dolly. This is always tricky, and the dolly tongue could flip up--right into the fuel tank or bottom of the trunk.
My dolly experience is only secondhand, but I'm thinking this might be real hard to do.
Larry
01-24-2023, 05:27 PM
I was always told that you shouldn't use a tow dolly to tow with the rear wheels on the dolly because the weight of the engine at the end of the dolly will increase the likelihood of a "pendulum" effect (i.e., tail wagging the dog). I'm certainly no expert on this, but just relaying what my Master Tow dolly dealer told me.
2019 Georgetown GT5 31L5
01-24-2023, 08:15 PM
I’ve worked for U-Haul for 38 years and have set up a ton of towing vehicles. DocP is absolutely correct. You can’t tow the car backwards because of not enough tongue weight on the tow vehicle and it will sway. Because of the weight of the TBird, that could easily be an out of control sway. Be Safe First
Jeff and Maria
Western Ma.
01-24-2023, 08:51 PM
I tow with a dolly but with front wheels up. I am no expert by any stretch of the imagination. There are several comments as to why this guy's idea is not desirable. Can someone give information more than an opinion why this is a bad idea? I for one would like to know in case I run into trouble on the road. The one point I see as valid is the length of the vehicle from the rear axle center line to the rear bumper and turning radius.
01-24-2023, 08:59 PM
So to answer your question, I use a Stehl tow dolly with electric brakes. I don't use lights on the end of the toad. One reason is the motorhome only has a 7 pin plug and the tow dolly requires a 7 pin plug, so, no place to plug in lights mounted at the end of the toad.
01-24-2023, 09:39 PM
You have to make sure the front wheels lock straight ahead if you mount a rear drive car backwards. Most dollies turn by allowing the front strapped wheels to turn as you turn corners. It would be a bit dicey at best.
That said, it's hard enough to deal with a low profile car on a dolly, and loading backwards will be a lot harder to get centered.
2020 Sunseeker 2860DS
01-24-2023, 09:48 PM
My guess when towing backwards that people may think can happen. I do not know either way, but have always heard that light tongue weight is bad.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
01-25-2023, 06:55 AM
Why rear axle on dolly (to keep miles off the odo?) Remove the driveshaft: Takes about 10 min
Towing wth rear axle on dolly, and that thing will be the worst ride ever, Can you say sway?
01-25-2023, 09:16 AM
Check to be sure your front bumper clears the dolly when hooked up before you buy. I just helped a lady remove her front bumper as the dolly had initiated it. Was not a pretty sight.
2022 Rockwood 2511S
01-25-2023, 09:38 AM
None of these towing problems exist with a proper car trailer.
Some cars can be towed all-wheels-down by some magic settings to disengage the transmission but I don't know if this one can -- check the owner's manual for flat towing but it seems you can't tow all four wheels down as you need a dolly for what wheels are "on the ground."
-- Chuck
