Old 04-15-2020, 06:16 PM   #1
Towing question
My wife and I recently moved into our Salem hemisphere 378fl full time. The issue is we bought it and moved in without having a tow vehicle. I found a 2002 Ford F-350 powerstroke with the tow package and all I can find is the tow capacity of 12,500 lbs when I look around our campground everyone is pulling 5th wheels with 350s or 3500s our rig is 11500 dry weight pin weight of 2100 lbs shouldn’t this 350 be more than enough truck to pull our rig?
Ron H1 is offline   Reply With Quote
Old 04-15-2020, 06:29 PM   #2
fonzie's Avatar
This link should help you......
https://blueovaltrucks.com/tech/pdf_...wing_guide.pdf
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 04-15-2020, 06:29 PM   #3
newer trucks have vastly improved towing capacity. Whatever the sticker on the truck says is what it's rated to tow. I'm sure the Powerstroke will pull it but it's the suspension, brakes, etc. that may not be up to the task. Ask to see the actual sticker on the truck, either door jamb or glove box should have the factory sticker.
nayther is offline   Reply With Quote
Old 04-15-2020, 06:30 PM   #4
With a little digging on the internet you should be able to locate the specs for the 350.
2012 Ram Laramie 2500 4x4 CC SB Cummins
2016 Flagstaff 8528RKWS
Patrick (order taker), Barbara (order giver) & Jasper (Dutch Shepherd) and now Jade (Boxer/Lab/Pointer hybrid) aka PB&JJ
PatrickY is online now   Reply With Quote
Old 04-15-2020, 06:32 PM   #5
Welcome - I am sure the people here will answer your question correctly.
For me - I am in the midsize TT and use a 2500 Ram. Again, welcome.
Ram2500 Surveyor 251rks
debit is offline   Reply With Quote
Old 04-15-2020, 06:53 PM   #6
Multi-Slacker
Welcome from SoCal!
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
CurtPutnam is offline   Reply With Quote
Old 04-15-2020, 07:40 PM   #7
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. F350 older ones have been hauling very heavy trailers like cattle trailers for years without problems.
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-16-2020, 07:44 PM   #8
Tfort's Avatar
I towed my hemisphere that weighed 12500, pin weight 2200 with my 2000 F250 powerstroke with no problem. When I weighed everything together ready to camp I was 100 pounds over the “rated weight” for the truck. I have since upgraded the truck to a newer 350 but still have and use the F250 to tow it occasionally.
Tfort is offline   Reply With Quote
towing
