01-29-2017, 05:39 PM
Truck stop diesel pumps + 5th wheel
Are there issues we need to think about for RVs rather than tractor trailers? What about DEF pumps?
2016 FR Sierra 377FLIK
2016 GMC Sierra 2500HD Diesel
01-29-2017, 06:01 PM
I use the truck lanes when traveling with the 5er... including using the DEF pumps... no issue
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
01-29-2017, 06:33 PM
I've only had two issues, one was the nozzles for the big rigs pump a whole lot more fuel faster than the passenger car lanes so be careful. Second I've run into two truck stops that would only sell from the truck lanes if you had a DOT number. Evidently they didn't have a way to calculate the tax and charge for it.
Computer Nerd
2014 Chevy Silverado 3500 HD Duramax
2016 Sandpiper 35ROK
01-29-2017, 06:38 PM
I buy the cheap def fluid from Walmart, works for me. I never use truck stops to fill up at
01-29-2017, 06:53 PM
no problem. as stated earlier the diesel nozzles are larger than the ones on the car islands. the hassle is that you need to position at the pump, take the credit card into the cashier (wait in line), go back and pump, them back to the cashier to complete the sale. advantage is they have window squeegies with long handles.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
01-29-2017, 07:36 PM
Computer Nerd
I ran into this in Indiana as well... not sure what I did wrong!
01-29-2017, 08:16 PM
Who Dares, Wins
I have heard that the tax can be different / not charged at truck lanes. But I have never had an issue with them. Only had one pump in MI that did not fit my truck's fill port but I could hold it in place. Filled my 36 gallons in 45 seconds LOL
I cannot use the DEF since the fill is in the hood and too short to reach.
2015 Chevy HD D-Max
2022 Impression 315MB
01-29-2017, 08:42 PM
Both loves and pilot/flying j have cards that will activate truck lane pumps without going inside. I really appreciate those high volume pumps.
2015 FR3 30DS Motorhome
2017 PrimeTime Crusader 315RST 5th Wheel
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
FMCA # F471293
01-29-2017, 08:45 PM
Who Dares, Wins
I could never get the J to work, but I have a Good Sam card, not a J credit card. I did sign up for the Loves but never used it yet.
2015 Chevy HD D-Max
01-29-2017, 08:47 PM
I just got one of those cards last week. I am hopeful it works.
But...........I also got a 37 gallon auxiliary tank, so not sure I'll need to get in line at the 'back pumps' with the truckers like I've had to. Probably will sooner or later, somewhere.
It is definitely impossible, for me at least, to get into the front auto diesel pumps. Well, actually, I can get in most of them. I just can't get out because they've all gone to pump lanes perpendicular to the street, not parallel.
Speedway.......I love 'em. Try to find them whenever I can. They have separate (and by separate I mean 200 yards away) truck and RV lanes, WITH DEF fluid pumps.
FROG AR-0019-242
01-29-2017, 09:09 PM
Some truck stops have an RV lane with smaller nozzles. Be aware they often have a sign hanging lower than the roof clearance. I scraped my front AC on the sign once (I'm full profile fiver with full size front AC )
If you use the big misleading get it stuck in the truck... been there done that. Run it slower so you don't get a diesel fuel shower when disconnecting... been there done that.
2014 Sabre 34REQS-6
01-30-2017, 12:13 AM
Some of the pumps ask for DOT numbers, or truck numbers. One of the selections is to skip it. Never had a problem doing that and getting my fuel.
Mark
01-30-2017, 01:37 AM
Always Learning
Love them. Do make sure you pull forward after filling so the next guy can start pumping.
http://learntorv.com/diesel-fill-ups...e-a-great-bet/
01-30-2017, 09:51 AM
I stopped in Loves truck stop to fuel and guesstimate the amount of fuel I need. They put the amount on my credit card. If I don't use the whole amount they said the difference will go back on my card. I fill up and drive away.
01-30-2017, 10:05 AM
One issue that no one has mention is the satellite pumps at truck stops. When you pull in to a travel plaza, make sure that the driver side pump is not the satellite pump. I have run into this issue sometimes. What you need to do if this happens is to put the primary pump hose on the ground and fill from the satellite pump. Also the Ram/Dodge trucks will take the truckers size nozzle without any issues at all.
Now when you go in the station to pre-pay the attendant will ask you if this is for diesel fuel or DEF, since they are dispensed from the same pump. If you do need DEF you might need to ask for a magnet to allow the DEF pump to provide you with DEF. The attendant has the magnet which you can borrow.
I also do not fill up anywhere in IN with my trailer attached because of the road tax issue in IN. I either fill-up in IL or some other surrounding state to avoid that problem. I have a hard time fitting into the AUTO lanes with my Cedar Creek.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
01-30-2017, 10:07 AM
Insert witty title here
If the DEF hose is too short at the pump, why not just use it to fill and empty DEF container then pour it in?
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
02-01-2017, 07:52 PM
Who Dares, Wins
That's all I'd do but I just never need the DEF when I am stopped.
2015 Chevy HD D-Max
02-01-2017, 07:56 PM
I can go for more than a full tank of diesel once the DEF warning comes on so I can fill at my next gas stop.
02-01-2017, 08:02 PM
Who Dares, Wins
Yeah I get 7 to 8k before I need to refill (about every oil change. This will go to the lower end if I am towing a lot during that period.
2015 Chevy HD D-Max
02-04-2017, 07:32 AM
DEF usage for me has been 7.5 gallons thus far with about 15k on the odometer.
2016 Ram 2500 6.7 Cummins Crew Cab
2017 Chapparal 360IBL
