Old 07-11-2017, 03:22 PM   #1
Violent shaking on 6% grade
Coming out of Denver on I-70 I started down that first 6% grade and was trying to apply a light brake (3 bars) and truck and trailer shook violently.
I had a 6% grade. 2 days ago and I had no problems.
What could cause this. I had the front alignment. Checked last week, tpms on truck and trailer indicated all was ok.
Super8mm is offline   Reply With Quote
Old 07-11-2017, 03:26 PM   #2
What is your tow vehicle? Plenty of Ford threads out there describing a death wobble.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 07-11-2017, 03:29 PM   #3
Boy, what a leap.
Next to know info and you jump to that? LOL.
325BH is offline   Reply With Quote
Old 07-11-2017, 03:30 PM   #4
I thought my signature line was showing.
Truck is a 2011 GMC 2500 HD Duramax pulling a 2013 356 Puma toy hauler.
Old 07-11-2017, 03:31 PM   #5
Taking a wild guess here, but sounds like warped rotors on your TV.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
bshort is offline   Reply With Quote
Old 07-11-2017, 03:35 PM   #6
Originally Posted by 325BH View Post
Boy, what a leap.
Right! I don't think the term "death wobble" has ever been mentioned on a RV Forum.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 07-11-2017, 03:48 PM   #7
That would be my first guess as well.
gloryracing is offline   Reply With Quote
Old 07-11-2017, 03:49 PM   #8
May be but under 45 mph or on fairly flat I don't feel any anything just smooth when I apply brake
Old 07-11-2017, 03:51 PM   #9
I had this on a motorcycle and that is exactly what my first thought was.
Old 07-11-2017, 04:03 PM   #10
Well now since his truck did not show up in his signature I was just guessing. The dreaded Death Wobble for Fords has been around quite awhile. I have an F250 but have never encountered the dreaded wobble. If you Google Chevy and death wobble, it appears that this also effects Chevies. Mostly it has to do with some loose of bad steering parts. I dunno maybe something is loose and the down hill jaunt made it worse. Google Death Wobble and see if it fits. There is even Youtube videos, go figure.
Old 07-11-2017, 04:06 PM   #11
fonzie's Avatar
Maybe just a bad hill with ripples in pavement....
Fonzie
Old 07-11-2017, 04:06 PM   #12
And guess what, I'm a member on the RV.net board and if you search death wobble you get two pages worth of reading.
Old 07-11-2017, 04:08 PM   #13
Wobbles's Avatar
Somebody call? Lol... My money is on warped rotors.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 07-11-2017, 04:09 PM   #14
Thanks, t chevked lug nuts on both and want see any sign of any seal failure
I would have thought the folks that checked the alignment would have caught OT.
Old 07-11-2017, 04:10 PM   #15
Actually I've seen pretty violent death wobble on an older motorhome, so RVs are not immune
Technically speaking, warped rotors pretty much don't happen. What causes the pulsating brake feel is uneven wear and/or uneven material transfer from the pad onto the rotor. The weird thing is that it can show more or less depending on brake temperature and pedal pressure. A few years back I had a Grand Cherokee that did vibrate and shake under light braking on a long downhill but had never any problems when braking normal or hard.
TheGerman is offline   Reply With Quote
Old 07-11-2017, 04:11 PM   #16
Actually it was fairly new resurface and nice and smooth
Old 07-11-2017, 05:30 PM   #17
Pillboxmc's Avatar
Check your u joints, that is what my semi did. U joint just starting to dry up, worth a try!
Tbd
2020 Trailhawk toad
Semper Fi
Pillboxmc is offline   Reply With Quote
Old 07-11-2017, 05:37 PM   #18
As stated there is no such thing as warped rotors/drums. It just dont happen.
From my experience that vibration you felt was most likely from the rear brakes/drums.
I would say from getting overheated and the rear brakes may be over adjusted.
over adjusted the rears grab before the fronts and dragging them down a 6% it would rear its ugly head like you experienced..
Just my opinion though.
Lawrosa is offline   Reply With Quote
Old 07-11-2017, 05:38 PM   #19
I will go take a look at them
Old 07-11-2017, 05:42 PM   #20
Its worth taking a look at when I get on level ground
