Old 01-23-2020, 10:56 AM   #21
I'm another with the Equalizer setup. Both me (48 years old) and my father (71 years old) have the equalizer and nor he or I have any issues handling the heads.
Maybe my father is an anomaly, but he still digs trenches, drags hot water tanks out of basements (he has 13 apartment buildings that he maintains) and pretty much does everything that he has ever done... just a little slower and with an arthritis limited neck and upper spine. The weight of that cast head is about the last thing that he would consider.
The equalizer works extremely well and for me and a 28" camper box (33' bumper to coupler) the sway is flat out eliminated, the front axle weight was put back to within 80 lbs of the empty truck and it made driving the box of air pleasurable. And it was $350 used on FB Marketplace. I love buying things like this for half price, you know... things that last decades and don't really wear out without massive amounts of use. Go used if you can, spend the saved money on something else you want or need.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 01-23-2020, 02:54 PM   #22
Tundra 2014
WDH
You do not say what you are pulling it w/. I prefer Equalizer, but for the trailer you are pulling should be fine. I do not believe yours has anti-way control, but if you are pulling w/ a 1/2 ton truck, fine. A lot is how they set it up.
Tundra 2014 is online now   Reply With Quote
Old 01-23-2020, 08:49 PM   #23
Go West's Avatar
Husky Centerline TS (a 4-point anti-sway hitch). My last hitch was a Hensley Arrow. The Hensley has an edge in sway control; the Husky provides better adjustment for weight distribution. Both hitches provide a safe, relaxed towing experience.
In addition to Equalizer and Husky, other options in a 4-point style are Reese Steadi-Flex and Curt Tru-Track. Lots of positive owner comments on those models on the E-trailer website.
Name:	Husky Centerline TS_LI (3).jpg
ID:	222285   Click image for larger version
Name:	Titan and  Grey Wolf 25RL.jpg
________________________
2017 Cherokee Grey Wolf 25RL
2017 Nissan Titan SV 4x4
Husky Centerline TS
Go West is offline   Reply With Quote
