08-21-2019, 01:13 PM
#41
GM Family
We're a GM family. My daily driver is a 2006 Tahoe. DW's is a 2006 Yukon XL, also serves as our TV. We don't have any particular strong loyalty. It just happens to be what we owned when we met nine years ago.
That said, we all remember when the American manufacturers were losing sales by the millions because the American cars rusted out so fast. (I was living in northern Illinois and southern Minnesota at the time and remember it well.) The US manufacturers have learned their lessons, or so we thought. Newer models have been robust.
Well, ever since the GM bailout, GM has been backsliding. There have been bunches of recalls for brake line rustouts--even scarier than losing a hitch. Some of the trucks have had recalls. A third-party aftermarket accessory provider, Dorman Products, has a full line of preformed stainless steel brake lines for all the GM pickups. The cars rust out, too. My son was doing some routine maintenance beneath his 2005 Cadillac CTS yesterday and discovered that the brake lines were so deeply rusted that he's afraid to drive it until he replaces them--and his car has been in North Carolina its entire life. There was a recall on the Caddy brake lines, but the dealer won't honor it unless you live in a northern state--strikes me as unethical.
I've also seen some suspension parts offered by aftermarket companies. There may be a problem there, too.
Our cars have the same hitch mount as the OP's. I will be inspecting them before any trailer is attached. (We just pulled a U-Haul utility trailer 400 miles without difficulty--fortunately no problems.)
Larry
08-21-2019, 02:04 PM
#42
Thank you. may I add a warning for those who leave a trailer hitch on their vehicle all the time. you never know when someone has backed into it or run into it while you were parked at the movies or shopping for new sneakers or groceries. leaving them on is not a great idea as not all impacts are visible.
 TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
08-21-2019, 02:28 PM
#43
I've learned a ton from this web-site and read it all the time. I appreciate you taking the time and shrinking your ego sufficiently to post a warning that just may save someone a great deal of grief. I applaud your concern for your fellow RV owners.
08-21-2019, 02:32 PM
#44
Originally Posted by NMWildcat
I thought it was funny comment/pic that added some levity to this thread that's about to go off the rails anyway.
You can take it as a harmless joke, or as a mean spirited jab. It's your choice......
LOL... I really thought once camping season started and cabin fever was thwarted, things would be better... guess not.
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=21
08-21-2019, 03:28 PM
#45
Originally Posted by keegantimber
This is far from a 2012 vehicle Pistol was driving. Get a grip
A bit sensitive to humor, satire and sarcasm?
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
08-21-2019, 03:36 PM
#46
WOW......That is UGLY. Glad it wasn't worse
08-21-2019, 03:42 PM
#47
So glad it didn't happen at highway speed on the freeway.
WOW... reminds me to be extra diligent with my total under the rig checks.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
08-21-2019, 04:36 PM
#48
Our first new MH was on a 1977 Dodge van cutaway. We special ordered it at the Chicago RV show. The factory welded the hitch onto a unit body platform. We were returning from a vacation driving normally and pulling a boat/motor/ trailer. We heard a dragging noise and thought it was a tail pipe. I slowed down and pulled off on the shoulder. Nope, not the tail pipe-the hitch was dragging.
Fortunately the boat tongue jack had a steel caster wheel that rolled for a safe stop.The caster axle hole was twice the size of the axle bolt. I jacked the boat trailer off and lifted the hitch and it completely fell to the ground. And, the safety chains were attached to the hitch. It was determined that the welds broke. Fortunately, we were very close to home and my father-in-law came to tow the boat home.
Since then, I have used undercoat and bed liner coating under our vehicles and on the hitch. A weld can break without being coated, but rust will defeat a weld over time. That is the only time we have had a hitch problem, but it is a event that will not be forgotten.
08-21-2019, 06:16 PM
#49
Originally Posted by deepseadan
I would also add to check your bolts and make sure they’re torqued down properly and not bent.
Thanks for the thought! I actually checked them at about 50 miles. Hand check, nothing had loosened. As soon as the rain stops- tomorrow hopefully- I will be getting underneath with a torque wrench I always carry to ensure they are to spec. Thought I would only use that wrench on the tire lugs!
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Traveled:2019-37 / 2018-30
08-21-2019, 06:57 PM
#50
My hitch ball sticks out a lot farther than most. It is painted orange. I pull a 5er and never use it. Around 1995 someone hit my new truck and caused damage. Since then I’ve been hit twice, no damage to the truck but can’t say the same for the vehicles that hit me. An Impala had to be jacked up and pulled backwards or I would have drug it home. Even painted some find it quite the knee knocker when getting too close.
08-21-2019, 07:10 PM
#51
So I just have to ask. If you never use it, why do you have the ball installed? Inquiring minds want to know
Scott and Liz - Southern NM
08-21-2019, 07:19 PM
#52
Good self defense
Yes, a trailer ball makes good self defense, especially in city traffic and parallel parking.
Larry
08-21-2019, 09:46 PM
#53
This will be the 8th Michigan we us more salt then you winter for this one.
Mike
2012 Silverado 2500HD 6.0 Gas 4.10 gears
1986 Buick Grand National 4700 Actual Miles
2015 Crusader 28RL
Days camped 2014 33 . 2015 42. 2016 38. 2017 35. 2018 41. 2019 43. 2020 42.
08-21-2019, 09:57 PM
#54
Really is that funny? Why not remove the hitch? Hard to believe for sure.
2017 FR3 28 DS
08-21-2019, 10:13 PM
#55
CentralMePistol
Thanks for posting this rust problem. Might make other people think twice about not checking their rigs out on a regular basis.
I used to be truck driver I am anal about doing a pre-trip every day on my motorhome. It only takes a few minutes and most times I will get underneath on my back checking things out. Driveline, wheel lug nuts, tire condition, grab that driveline and check for loose u-joints. Take a small ball pene hammer and tap around and listen for loose bolts etc..
I have often seen folks leave camp sights and not even give their rigs a cursory check over. Not even check to see if trailer, towed car, lights are even working.
A few minutes folks could save you a big headache down the road. Just a few minutes that's all.
2017 FR3 28 DS
08-21-2019, 10:53 PM
#56
Yeah but what does it look like underneath?
I would never buy a used truck from a region that salted it's roads
Mike
08-22-2019, 01:34 AM
#57
True.
I had a 2000 Monte Carlo where the brake lines rusted out and failed while I was driving. Luckily, I live in a fairly rural area, and when they failed, I felt them get weak before they were gone altogether.
I also had a 2000 GMS Sonoma where one of the transmission cooling lines rusted through and sprung a pinhole leak. I noticed it when is started shifting funny and slipping. I replaced it with rubber lines, but the damage had already been done, and it was never the same.
I now check the underside of my vehicles when I'm doing oil changes.
2020 Cherokee Grey Wolf 18MT
TV: 2014 RAM 1500 5.7 Hemi
08-22-2019, 07:08 AM
#58
In SoCal with all of the stop-and-go traffic a lot of pickups and SUV's leave their hitches in full time. It's a first defense against being rear-ended and saves many bumpers . . . for the lead vehicle at least.
08-22-2019, 07:22 AM
#59
a lesson learned from anglers - hook and release?
08-22-2019, 07:38 AM
#60
Not in SoCal. If their car can still move, they usually back up and take off.
