Old 07-12-2020, 05:56 PM   #1
WDH
Looking for opinions on Curt weight distributing hitches. I have a Rockwood 2706ws trailer with UVW of 6740 lbs and CCC of 2104 lbs. Hitch weight is 844 lbs. Looking to purchase this WDH Curt #17222 rated to tow 10,000 lbs to 14,000 lbs gross trailer weight and 1000 lbs to 1400 lbs tongue weight. Any comments or opinions.
2013 GMC Sierra 2500HD
2020 Rockwood 2706WS
Reggert is offline   Reply With Quote
Old 07-12-2020, 06:18 PM   #2
john5646's Avatar
I can tell you that I’ve been the happiest with the Equalizer hitch. I switched to it 2years ago. They have been around along time. And patents keep others from coping this trued and true design. Installed correctly, following there specs and you will not be disappointed. Only product better is pro pride. That is a completely different animal and it is good butt..., must will find its expense somewhat complexing. Most wdh will perform but many are sold as a better mouse trap. So as said my two cents will be, Equilzer, if your wanting to switch.
john5646 is offline   Reply With Quote
Old 07-12-2020, 06:24 PM   #3
Not familiar with the Curt model, but Curt is usually quality.We have the eaz-lift 1200. Makes a huge difference. We paid $250 for it with the anti-sway. If you're getting the WDH, definitely get it with anti-sway.
Jim and Michelle + Family
Rancho Cucamonga, CA
2020 Rockwood Roo 233S
2013 Ford F150 SCrew, 5.0L, tow upgrade
Old: 2003 Jayco Kiwi 23D
Jim_74 is offline   Reply With Quote
Old 07-12-2020, 06:31 PM   #4
Multi-Slacker
If you are happy with chains and bars then the Equalizer is the most recommended hitch. We switched from a Husjy Centerline to the Andersen and the absence of bars and levers has left us nearly ecstatic - to say nothing about not having to do all that jacking up and down. My wife can and does pull the hitch head in and out because it only weighs 45 lbs. BTW, our TT also goes ~9K lbs.
Have you looked at the Equalizer and Blue Ox - and the Andersen?
Safe Travels
CurtPutnam is offline   Reply With Quote
Old 07-12-2020, 06:38 PM   #5
glsimms's Avatar
I'm happy with my Ox.....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 07-12-2020, 06:42 PM   #6
I haven't really looked at any other ones. I guess I need to. A friend of mine has the Blue Ox and likes it but it seems a little pricey
Old 07-12-2020, 08:07 PM   #7
X2 and the 4pt equalizer has no chains just bars
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
