06-21-2012, 09:09 AM
(Kim)
WDH adjustments on trucks with higher 'rear-ends'
I have noticed that many trucks have a raised back-end. My Ram is 3" higher at the back wheel well than the front wheel well; my question is this:
Do you still adjust the WDH the same as on trucks that are level front and back? Maintaining a change of no more than 1- 1/2 inches difference between front and back measurements, or is a little more 'settling' acceptable in the back of trucks with higher rear-ends?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
06-21-2012, 04:02 PM
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
06-21-2012, 04:06 PM
Brigitte
Curious too! Back of truck pretty high with the 20's on!
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
06-21-2012, 04:27 PM
My f250 is about 2.5" higher in back. Ford specifically says that wd bars should be adjusted to eliminate 50% of front end rise.
So it may be diff depending on manufacturer.....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
06-21-2012, 04:51 PM
Missing Link
Go by the owners manual of tv. My chevy is 3" higher in rear. My owners manual says to adjust the wd so the front wheel well is the same loaded as unloaded.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
06-21-2012, 04:53 PM
I had a leveling system on my 1500 Z71 which raised the front level to the back, made for a very nice look. I'd like to do the same on my 2500HD but the WDH is set up so perfectly I don't want to alter anything. Either way, I would think keeping the front wheel wells the same height with or without the trailer is key.
2016 Wildcat 29RLX
2011 GMC Sierra 2500HD Duramax CC
Banks tuner, airbox and filter
Rancho RS9000XL's and Firestone airbags
Pullrite Superglide 18k hitch
06-21-2012, 08:01 PM
My rear height is 3 " higher than front. When I attach the 5er, the rear squats about 2" . This is with Timbrens. I know, the thread is about WDH but I thought I would share my experience.
06-21-2012, 08:49 PM
mine is pretty level with the wdh all set up, and about 2" higher in the rear unloaded.
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
06-21-2012, 11:56 PM
My truck drops 1 1/4" when I add the trailer to it, adding the WD bars it raises it a 1/4" so it only drops 1" from the original height. My front end height never changes. The rake will always be there unless you add more weight or level the front end but that depends on the truck. I say don't worry about it &
06-22-2012, 12:15 AM
It doesn't have a lot to do with the rim/tire combo since both are the same F/R. The independant front suspension is what drops our trucks so much more in the front. The 20" rim over 17"s only add about 1" overall height to the truck (31" overall on 17's. 33" overall on 20's).
I was going to order the 2" leveling block kit, but I like how level it rides loaded so I will just leave it for now
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
06-22-2012, 06:26 AM
Wanna Be Camper
I shoot for the same amount of drop fr and rear. and there is 3 or more inches difference fr to rear on my truck till it gets it's new suspension.
John & Deb
2011 Flagstaff V-Lite 30WRLS
