Originally Posted by Jmkjr72
What are the ratings in the hitch of the truck and the actual ratings of the truck from owners manual. Wha is the real tounge weight of the camper is that 500 the mythical dry weight or is it 15% of the gvwr of the camper
^^This^^
Your owners manual will tell you at what tongue weight you will need the WDH. No harm in using it anyway, and you find the sway control is really what matters. And as mentioned above, the brochure weight is far under what the actual tongue weight is.
My F-250, according to Ford, can be maxed out on tow capacity at 15,000lbs and no WDH required. But I tried both ways, towing our relatively light weight 23' trailer and the difference with and without the sway control is very noticeable. Tows OK without it, but much improved with it.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
