If this were a 3/4 or more truck, I would not be concerned about the 1/4" front drop from original. However, being lower in the front means there is more weight in the front than stock. Depending on how much weight has actually been transferred, it is possible to overload the front axle and not realize it. Especially if this vehicle already has the largest powertrain package available at the time. Not all 1/2-ton trucks will have much front capacity.
If the front is lower than stock, it would be wise to get a scale reading, loaded for camping, including front driver and passenger. Probably not an urgent thing, but worth checking when you get near a CAT scale on your next trip out.
