Old 01-24-2022, 08:01 PM   #1
WDH setup and torque
I purchased a Ram 2500 so I have to redo my WDH. The manual says to torque it to 380ft lbs. I can only find torque wrenches that go up to 250ft lbs. How do I get the nuts torqued that high?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2016 Dodge RAM 2500
kevin79 is online now   Reply With Quote
Old 01-24-2022, 08:23 PM   #2
Dazed & Confused
M&K Hoffman's Avatar
One possible way is to divide the 380 by your weight and that will give you the lever length of the handle needed on the bar that you stand on. Example, you weigh 100 lbs, 350/100= 3.5. The handle length would be 3.5 FEET long. Or seek out local mechanics to see if any can torque the bolts for you. The only torque wrenches I have seen that go that high are 3/4" drive.
BTW Can you use your existing hitch? I just replaced my Tundra with a RAM 2500 and the hitch is several inches higher. I do not have enough drop on my E2 hitch shank to get the ball mount low enough. I am either going to purchase a longer shank (more holes) for my existing hitch or replace with a different hitch.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 01-24-2022, 08:23 PM   #3
You might try a semi truck tire shop..
1100mike is offline   Reply With Quote
Old 01-24-2022, 09:08 PM   #4
Trailer Park Supervisor
NJKris's Avatar
What M&K said, that's how I did my ball nut which needed to be 250 ft.lbs No mechanic I know had torque wrenches that go that high, you would have to visit a specialty shop, one that deals with big rigs.
As M&K noted, torque is simply a force vector applied at a particular distance from the nut, on the handle of the wrench/breaker bar/pipe, whatever you have that is long enough. When you are heavy enough like me (275 lbs), slowly standing with one foot on the wrench that is parallel to ground will give you a torque of 380 ft.lbs when applied at approx. 1.38 ft from nut/bolt, whatever (380 ft.lbs/275lbs = 1.38 ft 'moment arm' (the distance from nut you have to apply the force).
Lots of interesting threads on this topic, just search 'torque'.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 01-24-2022, 09:50 PM   #5
I like the woods
jsalbre's Avatar
I used this torque adapter from Amazon along with the appropriate socket, a 2’ breaker bar, and 3’ of pipe.
https://smile.amazon.com/gp/aw/d/B009GLITFW
Unfortunately as with most things the price on these has gone up significantly. I bought mine 6 months ago for $70, may dad bought the same one a year ago for $50.
Rotate the setup so that you’re pulling up on the end of the pipe to tighten it and lift with your legs. I was able to get 430 ft-lbs this way.
Jeremy
Current:
2022 E-Pro E20FBS towed by a 2021 Jeep Gladiator Mojave
Previous:
2020 Airstream International Serenity 30RB towed by a 2020 Ram 2500 Limited CCSB 6.4 4x4
jsalbre is offline   Reply With Quote
Old 01-24-2022, 11:27 PM   #6
Camping the Natural State
It's 3/4" drive.
2021 Rockwood Ultra Lite 2614 BS
ARhappycamper is offline   Reply With Quote
Old 01-25-2022, 12:56 AM   #7
Originally Posted by ARhappycamper View Post
It's 3/4" drive.
Not a lot of 1/2" drive stuff is going to stand up to 350+ ft/lbs of torque.
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 01-25-2022, 11:37 AM   #8
I like the woods
jsalbre's Avatar
It's 3/4" drive.
Yes, as mentioned by Qwkynuf above 1/2” drive tools won’t handle that level of torque. You don’t want to be the one putting 300+ lbs of pressure on a breaker bar when the socket connection shears off.
Jeremy
Current:
Previous:
Old 01-25-2022, 11:41 AM   #9
Ejs4029's Avatar
When I bought my new hitch that needed adjustment I took it to my local RV repair shop they did it for me no charge
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 01-25-2022, 01:20 PM   #10
With one of these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2020 Gray Wolf 26RR
2016 Tundra TRD Pro
edc1911 is offline   Reply With Quote
Old 01-25-2022, 02:44 PM   #11
{Tpc}'s Avatar
Here is my question for those that have used the hand tools on this. Lets say you purchase a torque wrench, 3/4 drive, and the sockets that can properly torque all of this stuff.
Has anyone had trouble getting to the 300+ lbs of torque?
Say I want to readjust my hitch, and I get all set up somewhere and take it apart. Will I have trouble retorquing? Looking at the manual online it seems I only have to torque to 200 ft lbs.
2020 Salem Hemisphere Hyper-Lyte 25RBHL
2022 Ford F150 SuperCrew 3.5 Ecoboost MaxTow
{Tpc} is offline   Reply With Quote
Old 01-25-2022, 03:23 PM   #12
I like the woods
jsalbre's Avatar
As long as you get a nice long pipe (frequently called a "cheater bar") you shouldn't have any problem.
Jeremy
Current:
Previous:
Old 01-25-2022, 05:46 PM   #13
Good thing I wasn't on a forum 2 years ago. My 1/2" Snap-On breaker bar didn't even squeak when I put 430 ft lbs of torque on it.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is online now   Reply With Quote
Old 01-25-2022, 08:14 PM   #14
Okaaaaay. And?
I've twisted the pivot heads off of so many that I have lost count, when torquing or breaking loose axle nuts on front wheel drive cars. Enough of them that the tool truck guy has said that the warranty technically doesn't cover "abuse", like using the floor jack handle as a cheater. But I have had it work enough times that I still keep doing it that way.
The point is that 1/2" drive is not designed for those torque numbers. That's why the 1/2" drive torque wrenches don't go up that high. So, sure - it might work. But it equally might not.
-Qwkynuf
Old 01-25-2022, 08:26 PM   #15
Okaaaaay. And? I might have believed the keyboard warriors that doom would be-fall me
See my response to you above. You do understand that quality tools do not break off. Good stuff bends when too much cheater bar is used.
Old 01-25-2022, 09:02 PM   #16
... the warranty technically doesn't cover "abuse", like using the floor jack handle as a cheater. ...
I thought I was the only one who did that.
In my case it was because I was in an awkward position under my trailer, not because the torque requirement exceeded the capability of my wrench.
Edit: I misread that. I used the actual jack, not the handle.
TV: 2016 Ford F-150 SCrew EB RWD Lariat MaxTow
RV: 2020 Rockwood Mini-Lite 2507S
On order: 2022 Ford F-150 SCrew EB 4WD XLT HDPP. It might be 2023 before we see it.
chriscowles is offline   Reply With Quote
Old 01-25-2022, 09:46 PM   #17
I do understand that tools break when used outside of their design parameters, yes.
I also understand that anyone who claims to be able to predict the failure mode in that circumstance with 100% certainty must be living very well on their lottery winnings.
I do question the assertion that "Snap on" and "quality tools" are automatically assumed to belong in the same sentence. Spending more on marketing and warranty replacement/repairs does not exempt a manufacturer from the laws of physics.
I also reject the notion that it is in any way responsible to advise strangers on the internet that it is safe to apply more than double the recommended torque to a tool, and use "well, it worked when I did it" as the justification.
It's probably just a coincidence that only a couple of Snap On's 1/2" drive torque wrenches are rated for 300 ft/lbs ($700!!!), and most top out at 250?
Yep, that's probably it.
-Qwkynuf
Old 01-25-2022, 10:28 PM   #18
I didn't wanna be the one to say it. I weighed 270 pounds when I tightened my WDH and shank and all with my Craftsman 1/2" drive breaker bar and 3' pipe ! Worked great ! Would be slightly harder to do now at 220 pounds.
Old 01-26-2022, 02:51 AM   #19
I like the woods
jsalbre's Avatar
As said above, you absolutely can try to use a 1/2” drive setup to get 300+ ft-lbs of torque. You could never have a problem with that. You could also be unlucky and have your breaker bar end up like the one below (yes, it’s a Snap-On 1/2” drive).
I like my skin on my hands and my teeth in my mouth.
You also won’t find anything to register torque measurements that high in 1/2”, so why bother? You can say “stand on it” all you want, but if close enough was actually close enough they’d say “torque to about 350-400 ft-lbs”, not “torque to 380 ft-lbs”. “Close enough” is how the service techs at dealerships install hitches. I’d rather do the job the right way. Again, could you get lucky? Sure, but why risk it?
Jeremy
Current:
Previous:
Old 01-26-2022, 05:01 AM   #20
Now we have torque and wrench police.
With 270 pounds and a 3' pipe I got it tight enough ! Nuttin aint loosenin up !
