Old 09-13-2020, 01:40 PM   #1
Weighed my truck waiting to pick up new 5er
I went to the CAT scales today and weighed my truck in the exact configuration we will be towing. Me, wife, full tank of gas, some tools and the Andersen Ultimate. 2015 Chevy 2500 4x4 CC 6.0 gas with Curt gooseneck and Andersen Ultimate. Also have air bags with remote.
Front: 4060
Drive: 3300
Total: 7360
With a 9500 lbs GVWR, that leaves me 2,140 lbs for the pin weight. Sticker on the truck's B pillar says CCC is 2,791. Wife and I weigh 400 lbs so the actual CCC is 2,540 as configured. Not too bad considering everything I added.
Trailer is a 2021 Salem Hemisphere 290RL.
Here's the weight sticker on the trailer we are buying (9,772 dry weight):
Here's FR's specs for the trailer:
SPECIFICATIONS
Hitch Weight: 1825 lb.
UVW 9919 lb.
CCC 2106 lb.
Exterior Length: 33' 8"
Exterior Height: 12' 7"
Exterior Width: 96"
Fresh Water: 57.00 gal.
Gray Water: 62.00 gal.
Black Water: 30.00 gal.
I plan to tow the trailer from Couch's RV to the same CAT scale I just weighed the truck.
So, any bets on what the actual pin weight will be? Hope it's not too much over 2,000 lbs.
corn18 is offline   Reply With Quote
Old 09-13-2020, 01:47 PM   #2
2140 . lol
MR.M is offline   Reply With Quote
Old 09-13-2020, 02:40 PM   #3
Swaggler's Avatar
I’d put my money on somewhere between 1,825 and 2,212lb.
Swaggler is offline   Reply With Quote
Old 09-13-2020, 06:07 PM   #4
I wouldn't even bother worrying about it you fill up the basement and the rest of the unit with all your stuff. If you're over the GVWR a bit I wouldn't worry about that either since you will be well under you axle ratings. Enjoy your new fiver.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 09-13-2020, 08:56 PM   #5
Brake is on left
The Evil Twin's Avatar
2001 lbs. Lol.
As long as your axles can handle it drive on!
The Evil Twin is offline   Reply With Quote
Old 09-14-2020, 05:11 PM   #6
2400 at max weight and 20%
boogiejack75 is offline   Reply With Quote
Old 09-15-2020, 08:30 AM   #7
Doesn't the hitch weight count as cargo? I think its hitch wt, pin wt, and people/luggage wt that total up for cargo.
Is this the reason you appear to be ok on your cargo number while over on GVWR? (assuming max trailer loading)
I am starting to think about moving up from a TT to a 5er and will need to decide between 3/4 and 1 ton truck. Its not that much more $ between them but I am wondering about ride, other issues.
It looks like the 3/4 is kind of marginal on the ratings for a 10000 lb trailer.
For a 1/2 ton it looks like you usually max out on cargo which seems to occur around 8000 lb(at least for my 2016 with a 1625 cargo). It looks like the much larger cargo capacity of the 3/4 is swallowed up with the hitch and the 20% loading of the 5er vs about 10% for a TT.
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
jwfrede is offline   Reply With Quote
Old 09-15-2020, 10:35 AM   #8
Lins's Avatar
I'm guessing the same between empty and fully loaded, could even creep a little higher
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 09-17-2020, 05:00 PM   #9
Picked up the trailer and went straight to the CAT scales:
Truck weights
Front 4060
Drive 3300
Total. 7360
Truck with trailer weights
Front 4100
Drive 5180
Total 17360
Trailer 10000
Pin 1920
FR Spec from web site:
Dry weight: 9,919
Dry pin: 1,825
Dry weight from sticker on trailer: 9,772.
That's with 2x30 gal full propane tanks and 2 x group24 batteries in the front. Remove 60 lbs of propane and 90 lbs of batteries and my pin weight would be spot on per FR spec.
So my guess is that the weights from FR are pretty darn close to reality. So much for fictional weights.
Old 10-01-2020, 03:52 PM   #10
Got the camper home, loaded it up with everything and then some and filled up the fresh water tank. Then went to the scales. All looks good. Right at GVWR for the truck but still have 800 lbs on the rear axles. And the trailer is 1105 lbs under GVWR even with full fresh tanks (empty grey and black). I think this combo will work nicely.
Corn
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL GenY
1600W solar > 618 Ah LiFePO4 > Victron MultiPlus II > Cerbo GX
Old 10-01-2020, 05:12 PM   #11
Brake is on left
Originally Posted by mr.m View Post
2140 . Lol
winner winner!!!
Old 10-01-2020, 05:49 PM   #12
Good to go. 5400 is nothing that rear axle. Congrats.
5er, truck
