Old 05-28-2019, 09:31 AM   #61
Originally Posted by jwfrede View Post
You are right. I had been looking at the 2106 towing guide since that was my vehicle year and the F250 is listed at 850lb, but for 2017 F250 diesel it lists 1800lb. Wow, they really upped the numbers in one year. And it's still 1500lb for the gaser.
Yeah, they said it was due to the new frame. When they made the body aluminum, it was a lot lighter, so they put all of that weight into the redesigned frame. I just got back from a weekend in Key Largo FL, 20-30 mph winds and it still towed great with no to very little sway. Kind of hard not to sway a little bit when the crosswind is hitting you at 20-30 mph. I tried 3 different speeds towing, 65, 70 and 75. I got the same MPG at all 3 speeds and it towed exactly the same. Averaged the MPG over 10 miles each speed on the flat Turnpike. When I dropped down to 60 due to the speed limit, it gained almost 1 MPG.
2019 Forest River Cherokee 294BH Limited
2017 F250 4x4 Diesel
Pure Luck is offline   Reply With Quote
Old 05-28-2019, 07:52 PM   #62
BillyBass's Avatar
Originally Posted by pgandw View Post
You should set your receiver height so that the ball is at the same height as the trailer coupler when the trailer is level. The more the ball sags from that height when hitched, the more force the WDH bars/chains apply to return the ball to that height.
Fred W
I check the height and it the same.But when I hook up it sag a bit would it be safe to raise the ball one hole
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 06-04-2019, 08:38 AM   #63
Michael in Georgetown's Avatar
I pulled my 4,800# TT with my Frontier -- and a WDH. All the specs were barely within limits without the WDH (before I learned the 2/3rds rule-of-thumb of not exceeding 2/3 of capacity). I can't imagine trying to pull it without the WDH.
Since then, I've upgraded to a Titan, easily coming in under 2/3 capacity -- but still use the WDH -- and I can barely tell the trailer's back there...
I do leave them off when I move it around the property when I re-position for something, but I won't take it out without the full safety net. To me, it's part of the (safety) system, like the sway bar -- for all the reasons many people replied here with.
Michael in Georgetown is offline   Reply With Quote
Old 06-04-2019, 09:08 AM   #64
What's this " 2/3rds rule-of-thumb of not exceeding 2/3 of capacity" thing? Never heard of it.
The manufacturers listed capacity already includes a safety factor to cover driving along highway speeds, hitting bumps, etc. You can also see a bit of a safety factor on capacity vs axle weight limits that assumes the cargo is not perfectly placed. Now maybe if you plan on putting the cargo to the limit and driving it around for a business for every mile you may have an issue eventually. Or perhaps many people are very poor estimators of what their stuff actually weighs but I see no reason to add an extra large safety factor.
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
jwfrede is offline   Reply With Quote
Old 06-05-2019, 02:27 PM   #65
I heard from a couple of folks that it's safest to try and stay under 2/3rds of the rated capacity. I can't say it was authoritative, and I didn't see it written down. I just assumed it was a "thing" that everyone followed (being brand new here). Yes, I know what they say about believing everything you hear, but it sounded reasonable to me. Same people said to add around 1,000# (ish) for cargo when you're fully packed up...
So, since my towing capacity on my Titan is around 9,000+ and my TT is 6,000# (loaded) -- I figure that's a good (safe and practical) ratio.
I take it back if it's not a "rule-of-thumb" but it's one that I feel good about so I'll stick it on *my* finger... ;-)
Retired Air Force
Rockwood Mini Lite 2104S, with a Titan
Old 06-05-2019, 02:50 PM   #66
dannyabear's Avatar
Good thinking on your part; unfortunaly, most on here think weight ratings are just 'lawyer talk' and its OK to go 10-20% over
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 06-05-2019, 03:01 PM   #67
Sorry, I thought you were referring to cargo capacity. For towing capacity it can make sense to be under manufacturer numbers. The manufacturers seem to jack up towing capacity based on hp for a given vehicle. I have an F-150 with 325 hp so they give 12000 lb towing capacity. My brother has similar truck and tows around 7000 lb and has had brake issues in the rocky mtns. I wouldn't pull more than 8000-9000 lb or so with my truck in Florida and maybe 7000 lb out west. But if I had the 2.7 l engine and they said 7000 lb towing capacity I might do close to the 7000 lb since the brakes are the same. Might be unhappy on the uphill but its not a safety issue.
Jeff
2016 APEX 215rbk
Old 06-05-2019, 03:37 PM   #68
Roger that. Perhaps I miss-framed it as a safety thing, and not a practical rule-of-thumb-advice thing, subject to a multitude of various factors...
...and still getting all the lingo down (just learned what DW/DH stood for a few minutes ago!).
Retired Air Force
Old 06-06-2019, 04:38 AM   #69
BigH's Avatar
... For towing capacity it can make sense to be under manufacturer numbers. The manufacturers seem to jack up towing capacity based on hp for a given vehicle. ...
http://www.trucktrend.com/how-to/tow...s-the-standard
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 06-06-2019, 06:24 AM   #70
Thanks. Just did a quick read. The brake test is not adequate. They need to add repeated braking to test brake fade. I remember reading Motor Trend and Car and Driver years ago and they always had brake fade tests and comments. Not that one would drive a truck and trailer like that but driving in the mountains is a frequent occurrence for most campers.
They do have some handling tests but there should be some more focus on safety.
Jeff
2016 APEX 215rbk
Old 06-07-2019, 01:10 PM   #71
Yowman's Avatar
I worked part time for a local RV dealership in the Atlanta area for about 6 years. I saw quite a few new tag-a-longs and fifth wheels being brought in from the factory in Indiana. Non of these trucks had a WDH.
Yowman is offline   Reply With Quote
Old 06-07-2019, 03:55 PM   #72
Which makes sense, the set-up on a WDH takes time. Mounting the spring bar mounts on a new trailer draw bar could also make the trailer look "used".
Those transporters only have one goal, tow it to the dealer as fast as possible.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 06-07-2019, 04:15 PM   #73
They probably used a 3/4 ton or better truck. Hitch ratings are 800-900 and up.
Jeff
2016 APEX 215rbk
hitch, weight
