Old 03-10-2014, 02:21 PM   #1
weight distribution hitch adjustment
I just purchased a used Wildcat 28RKX and went to pick it up last weekend. I brought with me a WDH I purchesed to install. When setting up the hitch, the number of chain links required on each side was not the same. If I used the same number of links, 1 side would not be tight. The truck and trailer were on level concrete. When I got home, I installed bars and let chains hang to the ground. One side was about 1/2" higher than the other. When I switched bars, the same side was still high. I could adjust this by tighening/loosening the u-bolt nuts, but then bars would be set for each side. Is this normal, or should I take it back? Thanks
dgraham is offline   Reply With Quote
Old 03-10-2014, 03:21 PM   #2
Experienced Newbie
What brand and model wdh do you have?
Are the bars fully seated in the hitch head?
Any obstructions in the hitch?
Sent from my SGH-M919 using Forest River Forums mobile app
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 03-10-2014, 03:37 PM   #3
Resident Masshole
force's Avatar
Pictures may also help
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 03-10-2014, 03:40 PM   #4
The WDH is a Eaz lift 1k/10k. Bars are fully seated, but I will have to look closer to see if maybe there is a high spot inside the head tube
Old 03-11-2014, 12:15 PM   #5
Mfr is going to send me a new head unit the bars plug into.
2006 Dodge 2500 5.9 diesel
2013 Wildcat Maxx 28RKX
hitch, weight
