Old 01-12-2020, 12:13 AM   #1
Weight Distribution w/sway bar Curt MV
After reading 2 hrs
Have a 2018 ram 2500 diesel 4x4, planing to buy a Wolf Pup 18RJB (5,000#)
Have a question
So the trailer is not heavy at all, 5,000# is not the end of the world BUT I believe 1,000% in the weight distribution sway bar.
I am new at RVs, not at towing trailers. Have a 7x12 single axel w/brakes, landscape trailer 7,000# and kendon trailer.
RV is taller and bigger overall
I saw this at etrailer
https://www.etrailer.com/Weight-Distribution/Curt/C17062.html
What do you guys think ?
Need help.
vdelgadillo is offline   Reply With Quote
Old 01-14-2020, 12:07 PM   #2
Head Rambler
I prefer the units with built in sway control instead of the additional sway bar, but that unit should work fine.
You'll just have to be aware that you can't back up the RV with the sway bar attached, so you'll have to stop and disconnect it every time you need to back up.
Gotta go campin!
Old 01-14-2020, 12:17 PM   #3
madatme's Avatar
Dont care for the chains, I had one with the separate add on sway control on a 23 ft wolf pup, didn't like it, does have its cons, I suggest a husky center line that I use know and works great or a equalizer but its twice the money with same 4 pt function, good luck
Originally Posted by vdelgadillo View Post
After reading 2 hrs
Have a question
https://www.etrailer.com/Weight-Dist...rt/C17062.html
Need help.
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
madatme is offline   Reply With Quote
Old 01-14-2020, 12:40 PM   #4
Thank you so much for your help.
Do you have a part/model number.?
Thank you Again..!!
Old 01-14-2020, 12:47 PM   #5
I have never removed my friction style sway control bar when backing.
Why would it need to be removed?
MtBiker is offline   Reply With Quote
Old 01-14-2020, 01:17 PM   #6
Thank you Again..!!
https://www.etrailer.com/dept-pg-Wei...-pm-Husky.aspx
Pick the one that works for your weight.
2017 Wildwood 28dbud
2016 F250 6.7L
bcintx is offline   Reply With Quote
Old 01-14-2020, 01:17 PM   #7
Head Rambler
The biggest reason is because there's a warning on the unit not to back up with it on. The mfg. had a reason for putting that on there.
Beyond that, I've seen a couple that were bent while backing and a couple that tore the mounting screws out of the A-frame. I also saw one that sheared off the mounting ball. Keep in mind that you can turn a lot sharper in reverse than you normally do going forward.
Gotta go campin!
Old 01-14-2020, 01:29 PM   #8
Dave Lyon's Avatar
I'm similar in trailer weight and my TV is a 2500. I don't know that I even need the WDH for my trailer. However, I kept when I upgraded my 1500 to 2500.
I'm using the E2 Trunnion square bars. I'm not a fan of the chains as the bars hang too low for my liking. E2 is made by Equalizer, but, a 2 point sway versus 4 point with the Equalizer brand.
Based on my set up the E2 works great. I've has no issues with it and easy to use.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 01-14-2020, 04:25 PM   #9
Tundra 2014
WDH
Prefer the Equal-I-zer w/ the anti-sway built in. I have had several different bones over 35 years and this has been the best. W/ your combination, you will hardly know the trailer is back there. Having the sway built-in just makes it more enjoyable. Enjoy new trailer.
Tundra 2014 is offline   Reply With Quote
Old 01-14-2020, 04:29 PM   #10
Me too. I got a free hitch like the OP posted and got rid of it after just a couple uses. I still have the chain type for my boat trailer but don't use the sway control anymore.
I have bent my sway control doing a tight back up before. Probably just as easy to do as going forward but it seems I make tighter turns when i am trying to back into a spot.
babock is offline   Reply With Quote
Old 01-15-2020, 01:18 PM   #11
Lins's Avatar
Same here other than having to grease it and use the jackets to keep it quiet. Also need to keep torquing the bolts to keep sway working.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 01-15-2020, 01:24 PM   #12
Yep..bought the nylon perch covers as well after one use and hearing how much noise the bars make. I will sacrifice a little less sway control for less noise.
sway, weight
