Old 01-25-2020, 03:30 PM   #1
Weight Issue
I have a 2005 Chevy 2500 8.1 with an Allison transmission. What I need to know is if I would be able to tow a fifth wheel that has a 14,500 dry weight. The hitch is about 2,800, and over all weight is around 16,500. The new unit is 41.6 feet. Has anyone towed that weight with a 2500. Thanks
Utah Kid is offline   Reply With Quote
Old 01-25-2020, 03:33 PM   #2
BandJCarm's Avatar
Your payload is probably around 2,500 so you'll be way over that. But lots of people are doing it.
This is the most divisive discussion on this forum.....zillions of discussions on this very thing.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 01-25-2020, 04:27 PM   #3
Regular cab? Rear End? I see that motor and transmission have the possibility of towing your weight and then some. You might be close to your trucks GVW and rear axle weight depending on what the truck weighs all loaded and ready to travel.
2019 Hemisphere 272RL
2007 Silverado 2500HD 6L
Cabinfever97 is online now   Reply With Quote
Old 01-25-2020, 04:48 PM   #4
WEIGHT
I have an extended cab and long box 4 wheel drive and 396 rear end. Thanks.
Old 01-25-2020, 06:57 PM   #5
You'll be overweight, and you'll probably be struggling power wise. I mean I think that engine is in the low 300s for hp and mid 400's for torque.. I just don't see that being pleasant with 16K unless its mostly flat terrain, which it may be.
I know this 8.1's are workhorses but thinking your pushing its limits. I think the tow limits are like 10K or so aren't they?
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 G56
ronheater70 is offline   Reply With Quote
Old 01-25-2020, 07:35 PM   #6
That motor, transmission, and gear is much higher than 10k for towing. My 6L, GM transmission, and 3:73 is rated at 10k towing.
Old 01-25-2020, 08:15 PM   #7
Canadian Member
I have no idea whether you’d be over the “towing” (i.e. pulling) limit of your truck but I strongly suspect you’d be well over its GVWR and possibly its RAWR (i.e the weight it can carry/support). You may hear people say a 2500 is the same as a 3500 SRW except for some suspension component. Don't believe that without verifying it first.
Everybody has their own opinion on whether exceeding those ratings is something to be concerned about. You’ll have to decide that for yourself.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 01-25-2020, 08:37 PM   #8
TRD
OP previously stated he owned this same 2005 TV and Cedar Creek 5'er in his Nov. 2016 post. Has something changed to be inquiring today about towing this same combo?
2018 Micro Lite 25BDS (Flagstaff 26FKBS on order)
2019 Ford F150 XLT-3.5EB, Ext Cab, 10 speed, Max Tow, 1,910# Payload
2018-12 days/2019-83 days
TRD is online now   Reply With Quote
Old 01-25-2020, 08:48 PM   #9
Mr. Dan's Avatar
OP asked in post #1 if he could tow the 'new unit'.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 39
Old 01-25-2020, 10:50 PM   #10
Im seeing about 12K for an extended cab 3500 with the 8.1. Sure it fluctuates some based on options etc..
Ron and Kathy
Old 01-26-2020, 02:01 PM   #11
Fulltime family RVer
My big concern is that rig is going to run you up against the rear GAWR and tire load capacity once you start putting stuff into it.
If it were me, I wouldn’t do it.
Old 01-26-2020, 02:23 PM   #12
this is one ton dually territory with 4.10's imo....
that is a 15 year old truck as well... Maybe start looking for a new 6.6L gas one ;o)
curver900 is offline   Reply With Quote
Old 01-26-2020, 03:23 PM   #13
OP, that truck is rated to tow about 16k with a gooseneck. (12k for a bumper pull TT). You are already over 14k unloaded, and your overall weight is over capacity. Additionally, as some stated here, you will also be over payload.
IMHO, if you already have this set up try it for your type of camping. You will likely know before you get to your destination if this will work for you or not. If you take short trips it may not be problematic. But I wouldn’t go across the country like this. If you plan to go up Utah mountains-no way.
TV - 2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Drinks of choice: woodford reserve, knob creek & any great bourbon-just about any of San Diego’s craft beer and Pabst Blue Ribbon
Beachbourbon is offline   Reply With Quote
weight
