04-21-2016, 10:24 PM
#21
Does not matter how you slice it CCC is low and you are over. I was too.
B and B
05-14-2016, 09:27 AM
#22
Originally Posted by goduc
Live and learn I guess. Some just learn the hard way.
Now he is on another thread tell other people its OK to DO the same thing.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
05-14-2016, 11:05 AM
#23
Eeyup, I only have 53 years experience towing with half ton trucks. Suspension upgrades and performance modifications do work. Started out with a 1961 C10 swb with a 235 ci engine and 3 on the tree pulling my horse trailer to 4-H Gymkhana events. Got some booster springs from JC Whitney and some 8 ply 700x15 tires from Tractor Supply and down the road went. Dad couldn't get away most weekends so here I was at 15 with 10 years driving experience under my belt out on the open road.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
05-14-2016, 11:10 AM
#24
SO, you've been towing since you were 5 years old, huh?
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
05-14-2016, 11:22 AM
#25
Some of us started at a pretty early age.
05-14-2016, 11:23 AM
#26
Ranch kids start out early behind the wheel. I was spotting grain trucks in the field when I was 7 plus hauling loads of hay in to the home place following my Dad in another truck. Had to get a provisional permit when I was 12 to drive the 2 1/2 miles of county road to the school bus stop. When I turned 15 I went to the drivers examiner who knew me and he just handed me my drivers license and said here it is now you're legal.
05-14-2016, 11:29 AM
#27
Although I don't do it I don't think being 500 pounds over max vehicle weight is a big deal. But, being 500 over max axle rating should be a big no-no. My 1500, fully loaded and ready to go camping, is 280 pounds below max weight and 60 pounds below max rear axle weight. I can live with that. I just try to keep remembering the max weights are a limitation and not a goal.
BIRDS AREN’T REAL
05-14-2016, 12:33 PM
#28
More POPCORN please!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
05-14-2016, 01:43 PM
#29
emm-dee
thats close to ok, but tires should be in the weight category....NO D RATED TIRES....at least E, but F better. and what if you are showing alot of squat... then airbags are a must.
nothing like having the margin of big truck.
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
05-14-2016, 02:11 PM
#30
So 500 lbs over Max Axle Weight is OK? How far over Max Axle Weight do you think is safe?
The weights on Page 2 is on way home from picking up at the dealers.
05-14-2016, 02:37 PM
#31
It seems that "53 years experience towing with half ton trucks" you would of known a 1/2 ton truck with around 1800 Yellow Payload Sticker and a 5er with a dry pin weight of around 1500 lbs would probably exceed the GVWR and more important the Max Rear Axles Weights Ratings. There is only about 300 lbs of weight for the hitch. passengers and stuff in the trucks. A 3/4 ton Hemi with a GVWR of 10,000 and 6,000 Axles would of been a perfect fit and allow bunch of payload for stuff in the bed of the truck in in the forward storage of the 5er.
05-15-2016, 05:11 PM
#32
"close to ok" is not saying OK. [to exceeding gawr] my emphasis was on tires.... but 6000lb axles will bear overloading a little when you figure in manufacturer safety margin, but tires not rated for load you put your skin at risk......its funny that most E rated tires are rated at 3240 lbs so ford puts their axle rating at 6480....and axles bearings let go at worst..... blown tires...well you've seen the gruesome results on tv.
10040/31
05-15-2016, 05:16 PM
#33
The 1/2 ton Ram I have looked at didn't have 6,000 lbs axles but 3900 lbs axles, the 3/4 ton had the 6,000 lbs axles. He has 4400 lbs on the scale weight on 3900 lbs axle and it was weighed on the way home from picking it up at the dealers.
05-15-2016, 09:01 PM
#34
roger that.
10040/31
05-17-2016, 01:51 PM
#35
My 2014 Ram 1500 crew cab sport 4x4 had a payload rating of 1232. Front and rear axle ratings are both 3900 pounds. Even with air bags my 1,000 pound tongue weight was to much for the coil springs. The hemi and 8 spd had power to spare
I now have a gmc with max tow. My payload is 2050. Much better
My VW Passat has a higher payload rating than the ram 1500!!
Linc
05-17-2016, 02:10 PM
#36
Well at least you're on the other side of the country...I don't have to worry about your 53 years of 1/2 ton towing experience and your overloaded rig knocking me and my family off the road.....
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
05-17-2016, 03:12 PM
#37
I had a new 2008 Ram 1500 for a short time. Went for a load of floor tile on a pallet. When the forklift driver started to put it in the bed it squatted so bad he asked if I wanted to break it down. I told him to go ahead as long as the front wheels stayed on the ground. The job site was less than a mile away. The Ford dealer was 20 miles away which is where I went after being unloaded. Ram 1500 trucks look pretty and ride like a limo but are not meant to haul more than groceries.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
