Do you know how funny that sounds if it was not so serious?
The new truck just did not pull that much better
I am thinking that the trailer brakes were dragging all the time and that is why it feel like it had low power
Just guess how much power you will have when your brakes are not dragging....
I am also concerned about damage to the trailer brakes since they had 3.56 volts to them all the time.
I had a camper for over 10 years and talked to an RV service manager about changing out the break pads. He asked if I had any problems, which I said no. He said that the pads could last the life of the camper if used right.
These are electric, not hydraulic, which I think will not lock up the camper with the low voltage that you had. You may have burned some pad off, but I think that it will be fine. Find out why the voltage was low and set the breaks correctly. Then see how great your TV will pull that TT.
