12-17-2019, 04:05 PM
#21
I have bought my def from the ford house since I bought the truck.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
12-17-2019, 04:33 PM
#22
I buy at Walmart and check it before adding it with a $20 refractometer from Amazon. I have seen jugs in Walmart were many had broken seals and many had white residue on the outside.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
12-17-2019, 04:34 PM
#23
Originally Posted by primo20
FWIW I had a problem with my def system on my ram. Apparently the heater blew and the dealership said it had water in the def tank. They were not going to cover it under warranty unless I could prove I used mopar def. thankfully I had only been using it up to that point.
Thanks for the reply and additional information. But I am still wondering if anyone has had DEF problem with out-of-date DEF. Was yours within the "safe' date range?
2015 Forest River Solera 24R
2009 Honda CRV Toad
12-17-2019, 05:12 PM
#24
waybeck2018
[QUOTE=primo20;2238745]
Originally Posted by Ejs4029
Interesting on the def gauge. I’m 99percent positive I don’t have the same gauge cluster in my 2019 3500 high country. I know I get a message that says low def x km remaining.
I’ll look later today. I really miss the DEF gauge in the ram. It was similar to a fuel gauge. Always knew how much I had left and knew 4 gallons filled from half.
This GM I top up every 2500 km. Just did it before the snow flew. I hate filling it under the hood! Lol
My F250 has a method in their information menu to check DEF levels. PIA to do that, but at least it is an option. I use Blue Def or the Oreilly Band Def. No issues with either and have 101 K miles now. O'Reilly is comparable to WM price and keeps me out of the Big Box ripoff! IMHO
2012 F-250, 6.7 Super Duty Powerstroke; 2019 291 BR Primetime Tracer,
Days camped in 2018-61
Looking Forward to Completing This Map Soon !
12-17-2019, 05:18 PM
#25
So as thought here is the def gauge on my 2019 Chevy high country. I’m in Canada so possibly why it’s different than the example posted.
12-17-2019, 05:20 PM
#26
The def was still in the date range. I don’t believe it was a def issue. It sounded like a faulty heater they wanted to blame in non mopar def. that was he only point I was trying to make that if you have a warranty be wary of the dealer trying to make you think or require you to but the more expensive dealer branded DEF.
12-17-2019, 05:49 PM
#27
I have a 2017 GM Duramax and it displays “OK” till you hit the 29% and it counts down in the percent mode from there. Would be nice if it counted down all the way as you have no idea when the percent mode will kick in.
Mike & Fay
2013 Rockwood 8289 Diamond with 3.5" lift
2017 GMC 2500HD Duramax
Curt A20 c/w GM Puck system
2021 56 night’s booked
12-17-2019, 06:03 PM
#28
ISO standards for DEF: 32.5% urea and 67.5% deionized water
Because of the standard, there really is no better DEF brand than another. Get whatever you like, is cheapest, etc. As others have said, make sure if you purchase from a store, that it's in a sealed container.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
12-17-2019, 06:07 PM
#29
My Ford dealer fills the DEF as part of the oil change list of items. Only add Blue DEF when needed. Super Duty has at least two places that I know of to indicate DEF level.
2017 Open Range RES 347, 2022 F 450 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
12-17-2019, 06:26 PM
#30
It’s possible it’s mostly water. But I don’t know. Urea I thought was the main ingredient.
I’d have to check my manual but I don’t recall it specifically requiring house brand DEf.
I just know I had serious issues with ram service when issues crept up and always tried to get me somewhere.
From wiki:
"Diesel exhaust fluid (DEF) is an aqueous urea solution made with 32.5% urea and 67.5% deionized water".
This might be why your Ram dealer found water in your def tank.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
12-17-2019, 07:04 PM
#31
Originally Posted by upflying
The freshest def could be at the pumps at a truck stop.
I wouldn't bet on this statement, about three months ago I went to a SAPP Brothers to fill up on DEF, I had trouble getting to to start, I went back inside and reported that, the cashier said "yeah it doesn't get used that much", last time I bought DEF there.
#32
From wiki:
lol - quite possible! i just couldn't be bothered arguing with them any longer...
2023 Rockwood 2911BS | 2023 Silverado 3500 SRW Duramax
12-17-2019, 07:06 PM
#33
good to know - thanks.
I've only ever seen it say i was almost empty when i picked it up just prior to heading to FLA for a 2 week trip...took 2 4 gallon jugs in TN to fill now I'm in the "OK" range with a 4 gallon top up last month - which of course didn't take the entire jug.
12-17-2019, 08:19 PM
#34
well .... Super Tech DEF Diesel Exhaust Fluid 2.5 gal $7.88 .... BLUEDEF Diesel Exhaust Fluid, 2.5 gal $12.45 ... Mopar Replacement DEF Diesel Exhaust Fluid 2.5 gal $25.99 ... if it is all the same choice is easy
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
12-17-2019, 08:21 PM
#35
Now that I’m in a Chevy I’m using GM branded def to avoid any warranty issues. I only mention it in case other dealerships really believe their off brand def is superior to others.
The dealer was full of sh.... on this one. You hand them the warranty book and say show me where it says that I must use OEM DEF for warranty to be honored. It does not say that. Magnuson Moss Act addresses that crap.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
12-17-2019, 08:27 PM
#36
Whole heartedly agree. But that act is not an option for us up in the great white north.
12-17-2019, 09:09 PM
#37
Correct, next time ask them to test the DEF in the tank in front of you if they tell you it’s because of bad DEF that you didn’t purchase from them.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
12-17-2019, 09:12 PM
#38
Def
We also had an issue with our new Ram 350 - warning that def was bad and engine would shut off in so many miles. Took it in - they also refused to cover the service under warranty. They drained & replaced. They also told us about another person that had major damage that would not be covered. I went back & forth with Dodge trying to get the bill covered and said it was not in the manual to use only Ram product. BUT they pointed out a spot it did say that & would not reimburse us. Glad there wasn't any worse damage. We had never had a truck that used def so we were just buying it wherever also.
So going forward we always get at the dealership & keep the receipts in case of a problem.
Otherwise truck has been great.
12-17-2019, 09:21 PM
#39
I’ve only seen where they ‘recommend’ Mopar DEF, they will never put ‘mandatory’ in the manual.
1953 GMC 9314
12-17-2019, 09:22 PM
#40
What DEF are you using....
That’s like them telling you that you have to use Mopar oil. They cannot do that unless they provide the product for free here in the US, that is the law. In Canada you’re on your own.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
