12-17-2019, 09:39 PM
#41
I have a 2017 f350 . I don’t drive it a lot I’ve got an 02 7.3 farm truck I drive most of the time. The 17 model is the first truck with def I’ve had , it uses very little def I was wondering about the def in the tank going bad it’s exposed to various temperatures and it’s likely to be that a full tank could last up to a year . I had no idea how much it would use when I bought the truck it had 1/2 a tank and I filled it, that was in July and I still have over 1/2 a tank . I hope to be camping more next year and using it up but until then I was wondering what I should do ?
12-17-2019, 09:48 PM
#42
Originally Posted by DieselDrax
That’s like them telling you that you have to use Mopar oil. They cannot do that unless they provide the product for free here in the US, that is the law. In Canada you’re on your own.
Apparently our Canadian neighbors are covered by the Consumer Protection Acts, which sounds similar in nature to Magnuson-Moss.
"The law in Canada also states that a manufacturer cannot require a consumer to use OEM parts under the threat of voiding warranty. This practice is referred to as “tied selling” and is in direct violation of the Canadian Competition Act due to its anti-competitive nature."
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
12-17-2019, 09:49 PM
#43
Good to know! Thanks.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
12-17-2019, 10:54 PM
#44
I get free VW Adblue as part of the dieselgate "fix" at least for the next 4 years. It holds over 5 gallons and I think it will last my whole 10,000 mile oil change interval, but if not I just bring it to the dealer and they have to refill it. If it makes the 10,000 mile oil change I pay for the oil change but they top off the Adblue for free.
After that I think a delete is I'm my future.
12-17-2019, 11:11 PM
#45
Originally Posted by primo20
So as thought here is the def gauge on my 2019 Chevy high country. I’m in Canada so possibly why it’s different than the example posted.
Originally Posted by Gm Mike
I have a 2017 GM Duramax and it displays “OK” till you hit the 29% and it counts down in the percent mode from there. Would be nice if it counted down all the way as you have no idea when the percent mode will kick in.
I have the same on my 2015 2500HD Chevy Duramax.
Here is a release about the DEF fill and its gauge on the new 2020's Chevy's - "Diesel DEF tank/filler enhancements. The Diesel Exhaust Fluid tank is relocated farther back on the Silverado HD’s frame and out of sight from the exterior, and the inlet is located next to the fuel filler for more convenient filling. An electronic gauge readout for the DEF fluid level is added to the Driver Infotainment Center of diesel-equipped models."
I think that means they will tell have full it is instead of just being "OK".
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
12-18-2019, 12:43 AM
#46
Our new Fords, 2017 and newer have a 7 gallon tank with gauge .
12-18-2019, 05:25 AM
#47
That's what I thought, couldn't remember for sure what it was called up there. Thanks for the research.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
12-18-2019, 05:49 AM
#48
DEF tank holds 8 gallons ????
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
12-18-2019, 09:55 AM
#49
What kind of temps do you see? The lower the temp (especially now), the longer it will last.
The gauge doesn't tell you the shelf life which he's asking.
5.5 I believe on the pickups. 8 for the cab and chassis models.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
12-18-2019, 11:51 AM
#50
DEF
Our truck had a 1/2 a tank when we bought it and the dealer gave me a 2.5 gal jug of Mopar DEF. I used that and still have a 1/2 tank. I'll either use Peak Blue DEF or O'Reilly brand which ever is on sale when I need more.
Jim
Jim & Brenda
USMC Vet.
Asst. Fire Chief - Ret.
2018 RAM 3500 CC DRW
2017 Flagstaff Super Lite 29RKBS
12-19-2019, 08:00 PM
#51
Olemax
What DEF
I use the SuperTech from Walmart, because;
It's all the same stuff, water and Urea.
They sell a lot, so it's fresh, but I check the date to be sure.
It's cheap.
The included flexible spout is really beneficial to pouring it into the GM underhood fill opening.
The comments about storage life, storage temperature are correct. I keep the tank level low in hot weather, and keep any inventory in a cool basement or refrigerator. This stuff will eventually deteriorate to due to evaporation of the water and turn into a white crystalline solid, which can be seen where any is spilled and left to dry.
I hope this is helpful.
Olemax - NW NC
2011 Sabre RETS
2012 Silverado 3500HD CC LB
2006 Sierra 2500HD CC SB (sold)
12-23-2019, 07:47 PM
#52
I didn't see anyone else post this. I keep an empty plastic DEF container and fill it at the pumps at truck stops. When I need it, I fill my truck and then refill it at a truck stop pump. Approximately $7.25 to fill.
I've been doing this for over 4 years and have towed my 5th wheel around the country 3 times and from Florida to Alaska and back once. Going through Canada and the Yukon I'll carry two containers. No issues so far.
So why doesn't anyone else do this?
12-23-2019, 08:16 PM
#53
I use Blue DEF from Bi-Mart. Regular price there is $7.97 for 2 1/2 gallon box but I bought two boxes on sale at $6.99 each. They sell a lot and it is fresh.
My MBS (Sprinter) has a 6.6 gallon DEF tank. After 5000 miles I refilled the tank before getting any warning. I expect at least that on the current tankfull as the gauge shows just above half full with nearly 3000 additional miles
12-23-2019, 08:21 PM
#54
I’ve heard of a few people doing this. I don’t as I don’t see many pumps in my journies. I also don’t feel like hauling around empty jugs on my trips.
1953 GMC 9314
12-23-2019, 08:32 PM
#55
When I had my 250 I only ran Ford fluid. I have since sold it and still driving my older Duramax.
12-23-2019, 08:45 PM
#56
FWIW I had a problem with my def system on my ram. Apparently the heater blew and the dealership said it had water in the def tank. They were not going to cover it under warranty unless I could prove I used mopar def. thankfully I had only been using it up to that point.
Now that I’m in a Chevy I’m using GM branded def to avoid any warranty issues. I only mention it in case other dealerships really believe their off brand def is superior to others.
you should have told your RAM dealer that the DEF is about 95% water. I don't know the exact formula but that is close i think
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
12-23-2019, 08:53 PM
#57
Already covered in posts #28 and #30 in this thread, 67.5% water.
2013 Shamrock 21SS
12-23-2019, 09:09 PM
#58
Truck Stop brand
12-23-2019, 09:43 PM
#59
Def
Walmart brand, 41k miles no issues
12-23-2019, 10:38 PM
#60
Most convenient place is a truck stop, AKA where semi actually fill up, because lets face it truck drivers aren't going to buy def in gallon jugs daily unless they have no other option. and it should be getting delivered by the tanker VS swapping out totes or jugs.
If you go to a place but there is never any semi trucks there ... then yeah I suspect age might be an issue with the stuff in the tank-tote.
If a dealer told me bad def I would ask for a sample to be sent out to be analyzed.
One thing not mentioned is contamination. Dirt, dust, oils, funnels, cross contamination ETC. I'm not expert on this but from what I have been told cleanliness is of upmost importance. Sensors that say bad DEF may actually be DEF that has dirt in it, which would explain why a simple drain and fill works.
Even contamination from diesel is possible say you put the wrong filler in the wrong filler port. It happens.
Or you can own an older truck and not worry about DEF.
