09-24-2018, 10:13 AM
#461
Originally Posted by clarkbre
Today I got more acquainted with my new to me, 2016 F250. After some major repair and towing assessment of the '11 F150, we sold it and purchased the '16 on Friday night. Drove it from Portland to Seattle yesterday and today, figured out all the bells and whistles. Also took the toolbox off the bed in preparation for a tonneau cover and removed the "FX4" and "Flexfuel" stickers and emblems.
Nice clean look. I have to laugh when I see the stickers on Toyotas. Yes, I know its supposed to represent Toyota Racing Developement. But Americans pronounced GP as Jeep, how do we pronounce TRD? I pronounce it TuRD!
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
09-24-2018, 10:36 AM
#462
FX4 = F#%*s for ?
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
09-24-2018, 12:08 PM
#463
Front brakes, tonneau cover, recharged cai filter. And front brakes on DW's van.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
10-03-2018, 09:18 AM
#464
Getting front windows tinted and strip along top of windshield.
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
10-03-2018, 09:51 AM
#465
2007 WildCat 32QBBS
Installing brand new Kill Devil O-ringed cylinder heads. After 187k miles on stock head bolts I splurged a little on some parts including ARP studs, new stainless up-pipe, water pump, belts, hoses, seals & gaskets.
Here's a pic or two for the fellow Ford 6.0 guys.
A hoist is a must since they weigh in at 80 pounds each and I don't lift the cab, contrary to what many think has to be done.
10-03-2018, 09:52 AM
#466
2007 WildCat 32QBBS
Installing brand new Kill Devil O-ringed cylinder heads. After 187k miles on stock head bolts I splurged a little on some parts including ARP studs, new stainless up-pipe, water pump, belts, seals & gaskets.
A hoist is a must since they weigh in at 80 pounds each and I don't lift the cab, contrary to what many think has to be done. Attachment 188132Attachment 188133Attachment 188134
10-04-2018, 08:23 AM
#467
Installed front receiver hitch last night
2020 Rockwood UltraLite 2608BS
2017 F250
10-05-2018, 06:08 PM
#468
Failure is my business
Changed oil and filter on the 1500. Rotated the tires on the 3500.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
10-11-2018, 12:26 PM
#469
Slow at work so i did a coat of wash n wax to the truck before our long weekend trip
10-11-2018, 05:09 PM
#470
"Fixed" my emergency brake failure.
When trying to hook up the TT at the hillside campsite, my E brake ratchet would not hold. Actually the usual ratchet sound did not occur when pressing the E brake pedal. The warning lights came on and the brake held with foot pressure applied. So the cable was good. We just had to allow for the one inch drift back when I put the transmission in park.
APPARENTLY I have not used the E brake but the once when hooking up to go camping this time since I added a performance chip. The E brake release handle was jamming on the chip housing box! So I just had to pull the handle down, it went forward under the spring pressure and works as designed ;(
I'll probably pull the chip as I have not noticed any positives with using it. Just this one negative!
10-22-2018, 12:22 PM
#471
Put the sides on my fabric "garage". I got a 10x20" unit the club wanted rid of. A few bent poles but it works. I changed out a lot of the loose bungee ball fasteners with tie wraps. Prep for winter.
While doing the above partly after sundown due to other commitments, I apparently ran my battery down as I found out this AM. Checked, it's just under 6 years old. I'll be keeping an eye on it and my charger/starter in a handier location. It's a Motorcraft factory replacement, probably replace with the same.
10-22-2018, 12:33 PM
#472
Upgraded to a 2019 Ford F-250 6.7L 4×4 diesel. Crew cab.
2013 Flagstaff 27RLWS - Chloe'
2019 Ford F-250
NC
10-23-2018, 04:45 AM
#473
Beautiful truck. congrats!
2017 F250
10-30-2018, 07:30 PM
#474
Rotated my Good Year Wrangler tires.
10-30-2018, 07:46 PM
#475
2007 WildCat 32QBBS
Replaced the fan clutch with a new Motorcraft. Hope this one lasts atleast 185k miles too.
10-30-2018, 08:00 PM
#476
Has anyone changed out the stock air filter for a K&N or similar filter? If so was it worth the purchase?
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
10-30-2018, 08:15 PM
#477
Over the life it will save you on replacement filters. With the mass air flow sensors in newer vehicles lightly oil it or get an oil less filter. Unless you get a full cold air kit the hp gain will be very little.
10-30-2018, 08:22 PM
#478
X2. Don't get these filters thinking about MPG or HP gains. Not enough to notice, if any. My K&N is 11 years old and I just clean once or twice a year. For my initial $50 investment, I'm happy
Now I'm sure the K&N haters will chime in, but take it with a grain a salt . The filters are fine.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
10-31-2018, 05:05 PM
#479
Until your engine gets dusted. If you really think they are fine, start regularly start sending in your oil to get sampled to see if silica levels start increasing.
Super poor way of trying to save very little money.
Go to post #12
http://www.irv2.com/forums/f258/k-an...se-414408.html
10-31-2018, 05:11 PM
#480
Go to post #12
. That didn't take long.....
