06-11-2018, 08:24 PM
#381
Installed some new Super Nova V3 headlights enough of the amazon junk and bought some quaility lights. Also put on a 22inch light bar for those late night pulls.
06-11-2018, 09:37 PM
#382
Originally Posted by TitanMike
Good move. Most tire failures occur in the last 50% of tread depth and are more vulnerable to puncture from objects they run over. Tires also loose ability to stop as quick on wet pavement below that depth. Tires need to be treated like batteries and when tread depth drops to 50%, "recharge them".
On a news report the other night they showed how a tire worn to the old recommended "Lincon's head on a penney" failed to stop in a safe distance on a wet test track while a tire weth enough tread to just hide "Washington's head" on a nickel stopped in a greatly reduced distance.
Squeezing the last miles out of a set of tires to save $$ could well end up costing a lot more than just money.
Yeah yeah. Replace them when you can see the air. Ha ha
2017 Puma 297RLSS
06-11-2018, 09:42 PM
#383
Last week the TV got two treats. The broken fiberglass bumper cover came off, and the steel was painted black to match trim.
And she got her annual bath. Looked so good after the wash, I hit her with Maguire waterless wash wax and rain xed the windshield.
The next day a member of my church asked, "Pastor, did you get a new truck?"
Ha, no. Washed it. Same old '04 Ram 1500. But looks good now.
Today I replaced the gas tank straps too.
Ready for vacation next week.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
06-20-2018, 08:17 PM
#384
I replaced the 26 gallon fuel tank of my 14 F150 for a 36 gallon fuel tank. It was a direct bolt on. Very easy to do.
06-21-2018, 08:21 PM
#385
Originally Posted by coachjeff1
Did that once but it was in a drag truck. It just couldn't handle the power.
06-25-2018, 10:22 AM
#386
This weekend I did what many will cringe about. Took my eye off the front of the 5th wheel in a tight turn around, and popped my rear window. The window is replaced, but making sure that doesn't happen again still needs to be addressed. I used the Reese Revolution hook up in my previous 5th wheel. That let the trailer clear the cab easy enough, at the expense of dragging the tires a bit in tight turns. And it seemed different backing up. This 5th wheel also has a Reese Revolution, but I haven't activated it yet because I wanted to feel the towing and backing difference. Since the trailer has the cab clearance issue available by moving the wedge, and a slider hitch is an additional expense... I am only wondering if the slider hitches also see issues with tires and axles on excessive drag during a tight turn?
06-26-2018, 10:36 PM
#387
Detailed the truck (And wife’s car)
Took truck to dealer. Oil change, alignment, warranty work to fix the seven pin power issue we’ve been having.
Ready to tow.
06-30-2018, 11:45 PM
#388
About 3 weeks ago my trailer breaks service warming kept coming on so I took it to he dealer since I wasn’t hooked to the camper. They replaced a relay and it’s all good now. Just got back from a 1200 mile trip to Smoky Mountains and KY lake. Truck pulled our 7000 pound 2618vs very well. I have a 6.0 l Chevy. I have considered diesel, but for the cost of the truck and fuel I can’t justify it. I got an average of 8.8 mpg for the entire trip. Not too shabby. If I had a heavier trailer or fifth wheel I would go to diesel but for now gas is fine.
Steve & Suzanne and the pup Teddy
2015 Chevy 2500 HD 6.0 L 4:10
2016 Rockwood 2616 VS
07-06-2018, 06:41 PM
#389
So I guess I am getting old. I finally put steps on my truck. The drivers seat was starting to get worn out from sliding in and out. I actually don't think it looks bad it is growing on me. Next is a new seat cushion then I am done for awhile.
07-07-2018, 01:51 PM
#390
Haven't updated since May 28th, have done a lot since then. New Toyo ATII's in 255/80-17 to fill out the fender wells a little better on the dually. Air Lift 5000 Ultimate with Wireless One compressor system installed. Washed and put a coat of Hydro Silex on her. Oil change, air filter change, fuel filter change yesterday. Oh and ordered a Nav update from the A7 to the A9 version. I think that catches everything up. Leaving for a week at Fort Wilderness this Thursday staying thursday night at Atlanta South RV resort.
2016 F350 4X4 CCDually Lariat with 6.7L and 3.73 gears
2016 Sierra 371 REBH
2015 Xpress H20PFC w/ Yamaha SHO 150
Days Camped: 2013-8 2014-16 2015-38 2016-86 2017-64, 2018-6 and counting
07-07-2018, 07:28 PM
#391
NH Maple Maker
I changed the oil and filter, greased the tie rod ends and topped up the fluids. I also set the tire pressures and rotated the tires. Heading to Campton, NH Friday evening to spend the weekend at Branch Brook Campground.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
07-07-2018, 07:32 PM
#392
Beat the breaks off it for 400+ miles from SE Va to our new home in E Tn.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
07-07-2018, 08:52 PM
#393
Checked front pads, grease front end.
2004 Ram Quad 1500
1986 Jayco1016PUP
07-07-2018, 09:14 PM
#394
4 new Bilstein Shocks, Rear Differential Fluid, Transmission Fluid and filter, coolant flush, Oil change. Tired now [emoji23]
07-07-2018, 09:30 PM
#395
Just before the last trip I added power fold tow mirrors to the F150...a great addition that proved it's worth during the 4,100 mile trip.
I had previously added an observation camera on the trailer, but rarely used the camera after adding the mirrors.
2017 Rockwood 2304KS
2017 F250 Lariat 6.2 4X4 Scab SB
ProPride 3P Hitch
Nights Camped 2016 = 31, 2017 = 59, 2018 = 79, 2019 = 78, 2020 = 50, 2021 = 61. 2022 = 84, 2023 = 68
07-09-2018, 08:38 AM
#396
Wanna Be Camper
Made an appointment to get the truck detailed prior to leaving on Sunday.
John & Deb
2011 Flagstaff V-Lite 30WRLS
07-09-2018, 08:42 AM
#397
I also added power fold/extend tow mirrors mirrors, I absolutely love them especially when putting the truck in the garage.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
07-09-2018, 08:52 AM
#398
This weekend I installed the Dee Zee Tailgate Assist on my RAM 2500 should have done it sooner the truck sits high and the tailgate is heavy this product slows the decent of the tailgate with one handed operation now Only a few minutes time to install and $26.00 on Amazon.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
07-09-2018, 09:07 AM
#399
Canadian Contingent
I loved my Ram 3500 CTD a little more today than yesterday.
Wife says she hates having to compete with my other love.
Les and Bonnie with 4 Leggers Bella and Shelby
2011 Cedar Creek Touring Edition 36RE 3 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Anderson Ultimate Hitch
07-09-2018, 09:12 AM
#400
Changed the oil and filter this weekend and I'm glad i did. Since moving to MN, i let the oil change places change my oil one time each year, usually in Jan. This year they got another crack at it because we got a foot of snow in April. When i changed the oil this weekend, the filter I took off was 1/3 the size of the filter i bought to put on. I even went inside the house and double checked to make sure i bought the right filter.
Idiots.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
