02-06-2020, 07:32 AM
#741
It may be somewhere above, but brake fluid is hydrophilic, it draws water. Water compresses, not as much as air but it does. So changing the fluid every say 8-10 years, willkeep brakes from get spongy from water in the fluid.
Blinker fluid is a whole other matter.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
02-06-2020, 08:30 AM
#742
X2. Nobody does it, but they should.
It comes out pretty gross, considering it's supposed to be clear.
02-06-2020, 10:38 AM
#743
Just got my truck back from the dealer. Ford F-150 apparently have had a problem with their power door locks since 2016 at least. Poor door seals allow water in and they freeze up. My drivers and rear door would not unlock with the power locks, just the passenger side. The key did operate the drivers lock. VERY frustrating climbing over the front seats to unlock the rears.
NOT a recall, not a TSB, it's FSA 18N03 field service something for 2018. 2019s aren't listed so the dealer had to call Ford for authorization. Same prob as 2018s.
Anyways, bad freezing rain last night, power lock remote worked on all doors this morning
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
02-06-2020, 08:23 PM
#744
NH Maple Maker
Originally Posted by bareftn
I have never ever heard of anyone changing their brake fluid
antifreeze yes ever 2 years , oil, transmission, rear end lube but this is a first for me on the brake fluid
I've been working on Volvo cars since 1986 and changing brake fluid is something that has been part of the maintenance schedule the whole time. This is the first that I have heard of an american manufacturer recommending it.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
02-06-2020, 10:17 PM
#745
Japanese and German cars have been recommending brake fluid changes for years.
Especially now with more vehicles that have more complex braking systems because of collision avoidance and adaptive cruise control, there is more expense in the system other than just a master cylinder and brake calipers.
I lied...Guess it's actually 3 years. I changed it a year early. It's only a 30 minute job with my Motive pressure bleeder.
02-07-2020, 06:39 AM
#746
NH Maple Maker
I guess it's time for me to read the owners manual for my truck to see if GM recommends it too.
Russ
02-07-2020, 10:05 AM
#747
My Silverado 2500HD says 5 yrs.
"(7) Replace brake fluid every five years. See Brake Fluid pg 387."
2011 Traverse LT, 3.6L, FWD
02-07-2020, 10:43 AM
#748
HAHAHAHA!!
YES!!! XenoRev nailed it and either all the rest of ya' are asleep or not wanting to feed into it...something I CAN'T AVOID!!! Blinker Fluid, I replace mine at the same time I replaces the Mud Flap Filters too!! hehehehehehe
Ed & Chris, Empty Nesters (missing Josh & Jaclyn)
along with Blue & Tessa, Cat Explorers!
2020 Rockwood Roo 235s
2019 F-250 Diesel 4x4 Super Duty
02-07-2020, 05:20 PM
#749
I backed mine out of the garage, rolled out my snow blower, then put the truck back in the garage...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
02-07-2020, 05:55 PM
#750
Yes brake fluid absorbs water and water doesn't compress in hydraulic systems very well. Many brakes fail because of not bleeding the fluids in master and down to the wheels. I been doing mine every 4 years I will keep it that way but then mine is only a 07.
02-07-2020, 06:19 PM
#751
Corrosion is a huge issue as well. Even with my brake fluid changes I do on all my vehicles, got corrosion in an electric/hydraulic unit on my boat trailer. A $700 failure due to corrosion in the pump.
02-07-2020, 07:03 PM
#752
I got 4 new tires that have a snow rating ... they are awesome... day before I got new struts and shocks ... it’s a ssmmoooth ride now [emoji16]
02-12-2020, 04:07 PM
#753
More storage under the back seat
Installed two plastic storage panels under the rear seat to make storage bins. Uses factory holes. Should be standard. Also showing large storage bin I added a couple months back. It is held in with a single web strap and easily removed to use the large flat rear floor.
02-12-2020, 05:09 PM
#754
Just A Member
My new to me 2011 2500 HD Duramax got an oil, filter and lube, fuel filter, external trany filter, front & rear axle oil chg, transfer case oil chg & a new spare tire hoist. Rotated tires & checked brakes. Also removed, cleaned and installed new exhaust band clamp to fix leak. Should be good to go next month to the COA rally in New Orleans. I now know everything has been done and what oil is in it. 75k miles just broke in
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
02-12-2020, 05:59 PM
#755
Installed tow mirrors, and My Ham Radio
02-13-2020, 07:53 AM
#756
I did mine on tues but I went with the chrome ones
sorry no pics at this time
02-14-2020, 10:32 PM
#757
Do you get a lot of use of the ham radio
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
02-15-2020, 02:41 PM
#758
It depends on me I listen more than I talk, which shocks the hell out of the wife lol
02-15-2020, 05:50 PM
#759
Getting there....!
Lowered the height by 1 7/8" at the tailgate. This is a step toward getting more bed rail-to-overhang clearance.
I removed three shims (per side) from atop the leaf springs, and removed the airbags. I don't need them.
Here's the end result...(my driveway is on an upward angle, not level...)
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
02-18-2020, 07:06 AM
#760
Installed a tailgate damper.
2020 Rockwood UltraLite 2608BS
2017 F250
