Old 12-21-2017, 06:52 AM   #21
Originally Posted by Blender View Post
So many awesome reports and pictures of tundras in use and yet in other posts everyone states you need a 3/4 or 1 ton to pull a pop up camper!!! And yet here I see so many pictures and proof of tundras doing what some 3/4 and 1tons are doing.
Kudos Toyota!
There are those out here that believe you need a Dually to tow practically any thing....even a utility trailer. I have a 3/4 GMC, but I'm pulling 11,000 lbs. Trailer before...I used a 1/2 Chevy and a Ford and I pulled my popups with vans and 1/2 tons.
TheWolfPaq82 is offline   Reply With Quote
Old 12-21-2017, 09:30 AM   #22
Blender's Avatar
This is to answer shamrockthecasbah I cannot find the weight ticket to the truck by itself I had three weight tickets these just happen to be the ones I have in my photos on my phone that I uploaded..
However to answer your question yes the first picture of the weight ticket is of the fifth wheel by itself and it did throw me for a loop as to how the axle weights did change when connected to the truck.. this also changes based on how nose high the fifth wheel is so if i want the pin weight lighter I drop are on the airbags. Then the front axle on the trailer does what it is suppose to do.
I do know the weight of the truck with my wife and myself in it, it is 6680 ohh and hitch.. plus all upgrades the truck has.. suspension, wheels and audio..
The truck was purchased from The dealer New with the lift Kit and wheels only thing I’ve changed is upgraded stereo system and RCD BILSTEIN 5100 Shocks specific to the 6” lift because I did not like the blocks on the struts.. I added the air lift 5000 wireless airbags but I don’t add more than 30-45 psi based on road conditions.. the truck is 4x4 as well and it is the 5.7 with a 430 rear end hence my fuel crisis.. from missisissippi to New Mexico is definitely south and for aspirated engines that’s good news. However as you get closer to west Texas let’s say kerrville and Sonora oh also the Guadalupe mountains elevation changes and I do take it easy on the trucks speed usually 60mph in 4th gear on the climb. Not because of power loss but fuel stations tend to be a bit further apart. I haven’t been greater than 7% up and down because I just haven’t encountered greater yet.
As I have learned from the TRD specialists, the axle weight rating is put in place by the manufacturer as equipped meaning tires brakes and suspension for handling load carrying and stopping. Hub Bearings are very important to monitor.
The tires I have are definitely load range E and Kevlar armored sidewalls. The additional weight over the axles is split onto two hubs pretty much evenly. So as their TRD specialists explained to me the tundra was equipped with oversized bearings inner and outer.
The one thing I am going to have scheduled after the holidays is the rear end servicing. The truck has 56000 miles now and about 8-9000 towing. They did tell me if I tow heavy and long that it is recommended at 50k miles. On a side note I’m still on the original brakes and rotors.. still with over 70percent left.
As I have owned this rig for now three years, I am destined to say it’s dialed in and I enjoy her a lot.
I have read other posts where some bigger trucks encounter porpoising and chucking.. I get nothing of that nature.. I too have towed in some strong wind currents through El Paso Texas in 100 degree weather. Maybe I didn’t get a Friday built truck and fiver.
I have bumped into many rvers that have tundras and I get the question how does it handle, I say no different than when I pull my 24” center console boat. They then tell me latter they feel like they made a financial mistake getting the smaller fifth wheel of 32’ when the 34’ had everything they wanted..
I love input and people’s recommendations but this works for me and I love it when I get to my campsite and back in and unhook, press buttons and boom start the grill and plug in the fire stick.. Click image for larger version
Here is the info for my 2015 337Bar
https://www.rvusa.com/rv-guide/2015-...337bar-tr24847
Blender is offline   Reply With Quote
Old 12-21-2017, 09:42 AM   #23
Blender's Avatar
Originally Posted by cabranch47 View Post
I am thinking about may be getting a late model Tundra, either 4.6 or 5.7. I am interested in feedback from people that actually have one of these and what do they tow with it. Presently have a Flagstaff HW27SC high wall pup (about 3800#) and my current 1999 F150 with 4.3 V8 does not have the power or gearing for a trip out west through the mountains. At 70 yrs old I do not anticipate getting anything larger. Any opinions would be appreciated.
Cabranch, this post is not about me, but about a question you asked on a late model tundra.. I recommend the 5.7 with the 430 ratio rear end. Many here have shown pictures of the lifestyles they have. One other thing that has been told to me is there is no way you can pull a fifth wheel with a 5’5” short bed. Well guess what I have a slider hitch and I never slide it to the rear I always keep it in the travel position. Most new fifth wheels have front caps designed for short beds. Heck if power is what your after the dealer also does magnuson super chargers right at the dealer.. that is a specific TRD supercharger designed for the 5.7 I force. I’m sure 550 horsepower and sufficient gearing will move your flagstaff without issues..
The Toyota I have has had only one problem I put a stp fuel injector cleaner and it did not like that.. mine is a flexfuel and the computer is very picky for high octane fuels. It remapped itself and decided to make it run rich.. after a few fill ups it was back to normal.. hence if I were you flexfuel can be avoided.. I do use 93 octane when towing and 86-89 in town. All that happens is more mpg. Power stays the same no matter what the octane is in the flexfuel. The computer leans or makes the fuel mixture richer to compensate.
Old 12-21-2017, 09:28 PM   #24
HONDAMAN174's Avatar
Toyota discontinued the supercharger on the new units so they could get more points with the EPA with all the trucks being flex fuel. If it’s power you are looking for, an older non- flex fuel.
Just glad to get away
Old 12-21-2017, 09:44 PM   #25
Blender's Avatar
They are still doing them at the dealers as an after add on! If you have a flex fuel as in my case they swap out the whole ecu! I’m considering doing it I’m just not sure I wanna spend 6500-7500 dollars.
Old 12-21-2017, 10:53 PM   #26
We have a 2016 Tundra double cab with 5.7 and pull a Wildcat 311RKS which weighs 7500 loaded which puts us at 75%. However, we are close to max on payload. Payload is what you will run out of first. We get around 9 to 10 mpg when towing. I would recommend getting the Tundra with the larger fuel tank.
Harris85 is offline   Reply With Quote
Old 12-22-2017, 10:50 AM   #27
Thank everyone for your feedback. There seems to be a number of Tundra users, but in my searches, not many posts about them. One of my concerns was buying the 4.6 or the 5.7. I have decided on the 5.7. Not much difference in MPG and comes with tow package. I keep my vehicles for extended periods of time and I like the Toyota for reliability ratings. Now I just need to find some additional cash. I bought my 1999 F150 in 2000. Just getting over "sticker shock" on newer trucks.
Merry Christmas and thanks again.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 12-22-2017, 10:54 AM   #28
Blender's Avatar
Well hopefully the dealer works with you and this is the time of year to buy especially New Year’s Eve for year end closings.. good luck and get everything you want.. you’ll definitely enjoy the warranty.. I think they still do it “lifetime time warranty”
Old 12-23-2017, 12:29 AM   #29
Multi-Slacker
I have a 2014 Tundra 5.7L with 4:10 rear gearing. It pulls very nicely - ran right up Big Bear Mountain (> 10,000') pulling close to 9000 lbs. We are going to sell it because, our trailer, when loaded, puts us overweight at tongue and total payload. We love the truck but are worried about the safety issues and have aspirations of moving up to a fifth wheel when my wife retires. Other than the payload and weight issues, the only negative we can find is the tiny gas tank.
Safe Travels
CurtPutnam is offline   Reply With Quote
Old 12-23-2017, 07:51 PM   #30
Not for me, the fuel tank runs out about the time my bladder fills up
John & Mary Jo
Enjoying the adventure
Ky-N is offline   Reply With Quote
Old 12-23-2017, 10:33 PM   #31
Multi-Slacker
There is that - an attribute we share. I have to manage fluid intake for a successful voyage. Still, a 200 mile range is mighty skinny for out west.
Merry Christmas!
Safe Travels
Old 12-24-2017, 12:53 AM   #32
I tow with a 2007 Tundra (Just turned 88,000) with the 5.7 L and tow package. I have not weighed my trailer but it is 6400 lbs dry with a 660 lb tongue weight. I'm sure I'm over payload with my family and the loaded tongue weight of the trailer but under on the tow limit. I'm guessing somewhere around 8000 to 8500 lbs. I added timbrens just to keep the truck from sagging quite so much but other than that I have no issues driving the speed limit up hills and no problem going down with the tow haul mode on slowing me down when I touch the brakes and it downshifts. Just replaced my first set of front brakes. Rear are still original with plenty of life left.
ID:	158934Click image for larger version
kollinr is offline   Reply With Quote
Old 12-24-2017, 08:15 AM   #33
26DBH
Tundra tows our Gray Wolf just fine, no issues.
Name:	Tundra 26dbh.jpg
Lukegsdaddy is offline   Reply With Quote
Old 12-24-2017, 10:37 AM   #34
Blender's Avatar
Attachment 158934Attachment 158935
Beautiful setup and matching topper shell..
Old 12-24-2017, 10:38 AM   #35
Blender's Avatar
Grey wolfs are nice!!!
Old 12-24-2017, 11:59 AM   #36
AZ Pete's Avatar
What do you tow with your Toyota Tundra
08 Tundra with 5.7 engine, 28’ Passport. We have traveled every state west of Ohio, and most of western Canada, no issues towing. Would prefer a larger fuel tank, but we get by. Click image for larger version
AZ Pete is offline   Reply With Quote
Old 02-19-2018, 09:00 AM   #37
HAMMDOWN's Avatar
2013 5.7 Tundra w/Firestone air bags and pull a 2014 Forest River 8289WS 5ver
2014 Rockwood 8289
2013 Toyota Tundra
HAMMDOWN is offline   Reply With Quote
Old 02-19-2018, 10:28 AM   #38
VernDiesel's Avatar
Always intrigued me why despite terrible towing economy & tiny gas tanks that Tundra has a pretty loyal following amoung RVers. It’s compounded by the fact that gravity fed auxiliary tanks don't play well with gasoline. Anyway here is a link that may provide an easy affordable solution to help with this problem.
https://www.jmesales.com/enduraplas-...-20-25-gallon/
I transport RVs with the little economy diesel Ram so I’m always towing. Like the Tundra it has a tiny 26 gallon tank so when I came across these tanks I thought this is something even a gas truck can use and is easily removable if & when you need the bed space. Running 65 towing a typical double axle I can normally get 400 miles out of a tank and think that’s a little short. I can immagine a 250 mile range would be a pain in the butt.
The answer to what can my 1/2 ton tow; Generically whatever TT has a GVWR less than TV’s max tow rating. Specifically is found on CAT scale via weight distribution with TV TT & WDH. Best motor & gearing all 5 Mfgs within specs IE safe & stable normally to 8k but passengers & bedload reduce this. RAM 1500 ED max tow 9,200, max axle ratings 3,900, max 09-18 CVWR 15,950, axle weights me & gear 3,240 steer 2,560 drive
VernDiesel is offline   Reply With Quote
Old 02-19-2018, 10:33 AM   #39
Insert witty title here
I used to tow my Coachmen FE 310BHDS, 9900lbs GVWR with a Tundra but after a year of nailbiting being just at or even over my max load capacity, I upgraded to a Silverado 2500 diesel. Towing is a breeze now.
Having to fuel up every 150 miles and navigate those tiny gas lanes while hauling 36' of trailer was a major reason for me to upgrade too.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 02-24-2018, 04:17 PM   #40
Jjsav's Avatar
When I had my Tundra I towed this..... It towed great, but I will be going to a bigger 5W so i too went with a 2500 Diesel....
2018 Jayco Eagle 355MBQS, Andersen Ultimate Hitch
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
Jjsav is offline   Reply With Quote
toyota, tundra
