Old 05-02-2016, 12:41 PM   #1
NYDP77's Avatar
What is this called?
Everyone has probably seen this pop up on the forest river forum. My question is the bar on the front of the TV holding up the canoe. It looks like its attached to the tow hooks on the front of the TV. Didn't know they made such a thing, anyone know what it's called or where to buy?
DP
2013 Tracer 240 AIR
2014 Silverado 1500
NYDP77 is offline   Reply With Quote
Old 05-02-2016, 12:47 PM   #2
AquaMan's Avatar
It's simply called a canoe rack. Do a search and you'll find plenty
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 05-02-2016, 12:52 PM   #3
flymhi's Avatar
Thule makes one that can be front or rear hitch mounted
Thule Goalpost 997
Darby
2015 Denali Duramax 2500
2017 Coachmen 229TBS
flymhi is offline   Reply With Quote
Old 05-02-2016, 12:53 PM   #4
RedLdr1's Avatar
Boat / Canoe / Kayak carrier... See Here for an example. We carried a small fishing boat this way for years when I was a kid... Ours swiveled so you could mount the boat's transom on to the carrier then lift and pivot the boat on to the roof cross bars on our station wagon.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350
RedLdr1 is online now   Reply With Quote
Old 05-02-2016, 12:58 PM   #5
NYDP77's Avatar
Perhaps I'll be more clear. In this picture the bar in front is connected to the tow hooks. No need to install a front hitch receiver. I've searched canoe rack but have never seen one that attaches to the tow hooks in front.
DP
2013 Tracer 240 AIR
2014 Silverado 1500
Old 05-02-2016, 01:04 PM   #6
flymhi's Avatar
The pic you included is a hitch mounted unit. The blue tiedowns are steadying the side to side sway.
Old 05-02-2016, 01:05 PM   #7
It looks like there are straps from the support post to the tow hooks. Not sure if the post itself is mounted to the tow hooks.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 05-02-2016, 01:16 PM   #8
wmtire's Avatar
I can't see it clear enough on my computer to tell for sure, but could it just be the straps you are seeing attached to the tow hooks, like these below:
2011 Flagstaff 831 RLBSS
Old 05-02-2016, 01:21 PM   #9
One man canoe loader. Amazon
anthonymu is offline   Reply With Quote
Old 05-02-2016, 02:27 PM   #10
wmtire's Avatar
OK, I played with it in some image resizers. It appears to me that it's just the angle you are seeing it from.
I seem to be able to make out a center bracket going down under the front bumper to a receiver hitch (like in the pic above in post #8), as I seem to be able to make out it doing the L.
I think you may just be seeing the passenger side strap going to the tow hook, and then the center support...and from the angle it may look like the driver side strap, but you can't see it really at all.
So my opinion is, it's like the one in the pic I previously posted.
Maybe someone with better software can confirm or refute.
Old 05-02-2016, 02:55 PM   #11
NYDP77's Avatar
Thank you for the blown up image. It does look like straps are connected to tow hooks. I can now see the bar extended to the hitch.
DP
2013 Tracer 240 AIR
2014 Silverado 1500
Old 05-02-2016, 06:27 PM   #12
I think I saw one that connected to the tow hooks on etrailer.com
Kevinwak is offline   Reply With Quote
Old 05-03-2016, 04:22 PM   #13
Pathfinder75's Avatar
Transom carrier would need front mount hitch.
Think it was like this one on back of a Suburban. My dad and I used one like this many years ago when towing our travel trailer. The ford Truck is like in OP photo and Im guessing has straps or bars added to tow hook mounts for bracing. See eide boat loader | We Put Fun Back In Fishing
ID:	106823   Click image for larger version
2017 Montana HC 353RL added Disc Brakes, Progressive SURGE PROTECTOR.
2017 Ford F350 6.7L Dsl., CC, SWR, LB, B&W Companion #BWRVK3300 OEM Prep mtg.
PAST- 2012 Coachman Leprechaun 319DSF w/TOAD -2011 Chevrolet Equinox 4-cyl. AWD, 2008 Springdale 266RL, 2002 Outback 25FB
Pathfinder75 is offline   Reply With Quote
Old 05-03-2016, 05:12 PM   #14
RedLdr1's Avatar
That one of the Suburban looks a lot like ours did. The only problem was loading and unloading the boat constantly.... When my Dad upgraded to a 14 foot aluminum fishing boat, with an outboard engine, he broke down and bought a trailer.
Wayne
led
