Old 01-24-2022, 11:52 AM   #1
AKC
What practical difference is there between a 3/4 ton truck and a 1-ton truck?
Reading some recent posts where people were buying one-ton trucks made me wonder -- what is the practical difference between a 3/4-ton truck and a one-ton truck? I mean, if you got the very basic bare minimum for each. I have an F-250 and if you go online to look at the general specs, you'll see the Ford groups the 250 and 350 together. Do other manufacturers also do this?
I understand that there are upgrades available for a one-ton that aren't available for a 3/4-ton, but I'm just wondering about the difference in the basic models.
AKC is offline   Reply With Quote
Old 01-24-2022, 12:07 PM   #2
Others will disagree with me but, in a word, payload.
350/3500's will typically have some combination (or all) of:
heavier duty springs
heavier rated axle (sometimes)
upgraded shocks
larger/higher rated wheels/tires
sometimes - sometimes - heavier duty frame (but not often)
Other than that, there is no difference between them. My 2500 (for its model year) is different from the 3500 only in lighter springs, shocks and wheels/tires. It has the exact same axle that came on the 3500 for that year - I checked. I have upgraded the shocks and wheels/tires to the spec'd 3500's but the springs are still undersized for a 3500.
yukongold is offline   Reply With Quote
Old 01-24-2022, 12:12 PM   #3
Hi AKC - if you are comparing base model trucks, the difference is the springs. A F-350 comes stock with a helper spring pack in the rear. I am not sure if there is a difference in the front springs.
t.simpson is offline   Reply With Quote
Old 01-24-2022, 02:07 PM   #4
YukonGold hit it right on the head - payload. I replaced my F-250 with a similar 350 and gained 900 lbs of payload capacity. For our travel trailer, this wasn't necessary, but we are going to add a slide in truck camper and payload is the driver when it comes to camper selection.
Old 01-24-2022, 02:44 PM   #5
Of course plenty of folks will maintain the the rated payload of many 3/4 ton pickups is artificially low due to the manufacturers' arbitrarily maxing out the GVWR at 10,000 lbs when the trucks can actually handle more weight.
Some pretty lively discussions of this on the Heavy Duty RAM forums.
PodGeek is offline   Reply With Quote
Old 01-24-2022, 02:56 PM   #6
I like the woods
jsalbre's Avatar
I know you mentioned Fords, but in Rams the difference is huge. 2500s get coil springs in the rear and 3500s get leaf springs. The 2500 rides much better because of this.
Jeremy
Current:
2022 E-Pro E20FBS towed by a 2021 Jeep Gladiator Mojave
Previous:
2020 Airstream International Serenity 30RB towed by a 2020 Ram 2500 Limited CCSB 6.4 4x4
jsalbre is offline   Reply With Quote
Old 01-24-2022, 03:16 PM   #7
I am sure my Ram 2500 4wd has a #500 lighter rear axle than the 1 ton.
I know it has coil springs instead of leaf. Like a train.
Motor and transmission is the same. Perhaps different ration in the diff. dependent on years.
The shocks may be different.
My brakes and tires are the same size.
Mostly it was to mollify the DMV crowd nation wide about the commercial truck thing and more expensive license plates.
tomkatb is offline   Reply With Quote
Old 01-24-2022, 03:35 PM   #8
camper_Lucy's Avatar
a few model years back, but not that much has changed so it is still relevant:
https://news.pickuptrucks.com/2018/0...0s-differ.html
2019 Chevy 3500 4x4 Crew Duramax
2021 Gray Wolf Toy Hauler
2019 Street Glide
camper_Lucy is offline   Reply With Quote
Old 01-24-2022, 06:56 PM   #9
AKC
Thank you @camper_Lucy, that was a very informative article. It looks like it was just a more informed way of saying what everyone else was saying -- in most trucks it's higher payload.
Old 01-24-2022, 07:12 PM   #10
BigH's Avatar
There is no 10,000 GVWR limit on 3/4 ton trucks.
I don't know about Ram but both Ford and GM offer 3/4 tons above 10k GVWR.
21 Ram 2500 crew cab long box. 6.4 gasser 50 gallon tank.
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 01-24-2022, 07:42 PM   #11
BigH's Avatar
The article is false regarding the GM trucks (which would make me question other things...) and because of the early falsehood I didn't see a need to finish the article.
Fact: not all GM 2500 configurations use the same rear axle housing as the 3500 series srw as was stated in the article. I had a '17 and a good friend had a '18 2500. Not his or mine had the same axle housing as a 3500 srw.
18 Vengeance 28V
Old 01-25-2022, 09:01 AM   #12
Yep, the '20 and newer GM 2500 and 3500's have different rear axles, ring gear sizes, the 3500 doesn't have torque limiting in 1st gear like the 2500 does.....there's differences. This is with both having the Duramax.
2019S Mod Thread
https://www.forestriverforums.com/fo...ad-184896.html
2020 Rockwood Mini Lite 2109S
2021 Nissan Titan XD Platinum Reserve
01tundra is online now   Reply With Quote
Old 01-25-2022, 09:29 AM   #13
This was pointed out in some of the conversations that I read, but folks then mentioned that >10,000 lbs puts a truck in the "Class 3/Medium Duty" category with correspondingly higher registration fees and other requirements if used commercially:
If a vehicle has a GVWR of more than 10,001 pounds and is used for a business, including nonprofits, then it is subject to federal and state safety regulations for the safe operation of commercial motor vehicles. Vehicles over this weight are required to stop at state weigh and inspection stations, and drivers must follow regulations concerning hours of service and medical examination.
https://www.thebalancesmb.com/commer...cation-2221025
They cited these restrictions as potentially limiting sales of 3/4 tons rated at > 10,000 lbs and said that's why manufacturers typically kept the GVWR at/under that number.
Old 01-26-2022, 12:46 AM   #14
Somebody previous said the brakes are the same size! Boy are you wrong, the biggest difference is the brakes. You can add more springs, beefier shocks, air bags, yada, yada, yada, but you can’t put bigger brakes on a 3/4 ton truck without changing the entire drivetrain & front suspension. So your bottom line is…..much bigger brakes. That’s the main difference, The end,no brag, just fact.
Sbosserman is offline   Reply With Quote
Old 01-26-2022, 01:05 AM   #15
That depends on make and year. Some take the same parts. One must look up the part numbers for the two different trucks.
aircommuter is offline   Reply With Quote
Old 01-26-2022, 02:20 AM   #16
1/4 ton
TV: 2016 Ford F-150 SCrew EB RWD Lariat MaxTow
RV: 2020 Rockwood Mini-Lite 2507S
On order: 2022 Ford F-150 SCrew EB 4WD XLT HDPP. It might be 2023 before we see it.
chriscowles is offline   Reply With Quote
Old 01-26-2022, 03:36 AM   #17
As men we always want bigger.
An Remember the day you bought your first motorcycle/first rv. how soon did u want a bigger one...... It never stops there.
Abe Arctic Wolf 2021 29IRl
2017 Titan XD 5.0 Diesel 2018 Indian Roadmaster
Disabled Vet, IT Guy SW Fla.
wildmanabe is offline   Reply With Quote
Old 01-26-2022, 05:11 AM   #18
Camping the Natural State
You are saying the brakes are different on new F250 and F350's ? F250 is 3/4 ton. F350 is 1 ton.
2021 Rockwood Ultra Lite 2614 BS
ARhappycamper is offline   Reply With Quote
Old 01-26-2022, 07:03 AM   #19
I worked at oriellys about ten year ago. I remember that ford 250 and 350 ( non dually) had same rotor and pads. I looked up a 2019 250 and 350. It was random pick of newer model and I have no knowledge on other brands but the ford in 2019 appear same. Pics are provided before you say they aren’t the same compare either the top or bottom to each other. Click image for larger version
ID:	268175Click image for larger version
ID:	268176Click image for larger version
ID:	268177Click image for larger version
moose074 is offline   Reply With Quote
Old 01-26-2022, 09:24 AM   #20
SVTodd's Avatar
Bigger front brakes don't really mean that much in terms of towing an RV. The RV brakes should be more than adequeate to stop your RV with no greater strain on the tow vehicle brakes than normal. If you are pushing the limits of your front brakes while towing, your RV brakes are not working properly.
The argument about if your trailer brakes fail is also not relevant. Brake size is the not the limiting factor for stopping a vehicle one time. The coefficient of friction between the tire and the pavement is the limiting factor. I have no doubt that the front brakes of a 3/4 ton truck can lock up the fornt tires one time, no matter how much it is towing.
Brake size only becomes an issue in repeated braking and how fast they wear. Larger brakes prevent fade with repeated use, (i.e. descending a mountain swithback pass). If your trailer brakes fail the brakes on a 3/4 ton will stop the rig at least once. You shouldn't be doing multiple brake applications if your trailer brakes have failed.
So the only concern about brake size between a 3/4 ton and 1 ton would be how often you have to change the pads.
Also your contention that you can't put bigger brakes on a 3/4 ton is wrong. There are many aftermarket big brake kits.
2021 Adrenaline 34GM toyhauler
2015 GMC Crew Cab 2500 Denali 6.0 Gas
Propride 3P hitch
SVTodd is offline   Reply With Quote
truck
