Old 03-27-2018, 08:32 AM   #1
What size ball for 26dbh with a blue ox hitch
So our new 26dbh will be here in the next week and my plan is to buy a blue ox sway pro hitch for it. I understand the blue ox hitches donít come with a ball so I want to order one when I buy the hitch so for those that have this setup what size ball do I need to order?
Olotti is offline   Reply With Quote
Old 03-27-2018, 08:43 AM   #2
Nearing all are 2 5/16Ē
spydunks is offline   Reply With Quote
Old 03-27-2018, 01:32 PM   #3
Ejs4029's Avatar
Looks like if your going to go with a Hitch ball offered from Blue Ox they are both 2 5/16 but they come in two sizes one with a 1" rise and the other with a 2" rise so you would have to figure out which one you would need.
Maybe someone else can chime in if you have to go with a Blue Ox Hitch ball or can go with another MFG.
ID:	166349   Click image for larger version
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 03-27-2018, 01:38 PM   #4
Sorry for the confusion I just meant I was going to order any ball not necessarily from blue ox. But since Iím going through amazon I just wanted to order both at the same time.
Old 03-27-2018, 01:45 PM   #5
Ejs4029's Avatar
Sorry for the confusion I just meant I was going to order any ball not necessarily from blue ox. But since I’m going through amazon I just wanted to order both at the same time.
It's going to be a 2 5/16 but they do come in different heights and weight ratings from other MFG's just make sure to get the correct one for your application
TST 507 TPMS
Old 03-27-2018, 01:55 PM   #6
Whatís the best way to figure out the correct size? Call blue ox directly?
Old 03-27-2018, 02:13 PM   #7
Ejs4029's Avatar
What’s the best way to figure out the correct size? Call blue ox directly?
Yeah I'd give them a call I'm sure the first thing they are going to ask you are few measurement questions to get an idea if the standard shank that comes with the Blue Ox hitch will work in your application. I'm sure after determining that they can recommend the correct hitch ball for you.
1. Hitch receiver 2" or if you have a 2.5" and plan on using that or reducer sleeve.
2. What is the measurement from the ground to the top of the hitch receiver on your tow vehicle ?
3. What is the measurement from the ground to the inside of the coupler on your trailer ?
TST 507 TPMS
Old 03-28-2018, 07:15 PM   #8
My hitch receiver is 2Ē. Is this the std size that the blue ox comes with if say bought on amazon?
Old 04-02-2018, 11:22 AM   #9
Ejs4029's Avatar
Yes to my knowledge the Blue Ox Hitch ships with the standard 2" shank for the hitch receiver...Are you going to install and setup the hitch or have a dealer do it for you ?
The setup is going to be dependent on your Tow Vehicle and your trailer if your doing the install I suggest you read up on the Blue Ox Hitch installation instructions.
TST 507 TPMS
Old 04-02-2018, 03:02 PM   #10
I'm having the dealer install it when we pick up the camper.
blue ox, hitch
