11-04-2016, 10:26 AM
#581
Originally Posted by 2014 sierra
sounds like a durable rig. the pin box? sidewinder or airborne sidewinder? always wondered how well those worked.
The pinbox is called "Reese Revolution" same as the sidewinder, no air shock like the airborne. Never used an airborne pinbox. The hitch in my truck is a Hensley BD3, it has two shocks and two air bags.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
11-04-2016, 12:12 PM
#582
Reese Reveloution
Originally Posted by PhoneDude 8289
Truck is a 2014 Ram 2500 turbo Cummins short bed and averages 12 - 14 mpg pulling the 5er. Truck is stock, no lift. (see my sig) No slider, the 5er has the Reese Revolution pin box.
I have the retrofit version of the Revolution (Sidewinder) and it works great for towing and never having to worry about contact with the cab as I have a short (5'6") box on my Sierra. Since yours is factory my question is can you move the pin box from side to side by hand or does it only move when hooked up to the truck?
___________________________
2016 GMC Sierra 6.2L gas
half ton with towMAX package
2016 Crusader 295RST (5th wheel)
Camped 80 days in 2016, 42 in 2017, 42 so far in 2018
11-04-2016, 04:37 PM
#583
Crusin81
Pin box and 5th wheel reciever
Due to my newer RV I am needing to upgrade to be safer. I am looking at different possibilities. when I towed her home dry her weight was rated under 11000 lbs. however, loaded she has a capable weight of 15500 lbs. my current receiver is a 15000 lb husky with slider. it sounds strange because I have a 8' bed but when hooked up I was so close to the RV with my bumper I was only able to hook up "straight" or I would hit. to my surprise while towing her I had no trouble at all, making corners and everything. that husky receiver is a very simple receiver, no bells or whistles. never noticed ANY towing problems in the 300 miles getting her home other than terrible electrical install from the dealer (another story). This is why I was asking so many questions. To be a bit more clear of my situation, I am towing a 2014 sierra 5th wheel with a 1 ton GMC dually I might move up with my truck in the future as well (to a diesel), only currently I haven't seen the configuration I want. with the new technology the way it is, it would take out the guessing work and hopefully more dependable. (again, another subject) thanks, if you could fill me in on your opinion of your setup +'s and -'s it would be great.
11-05-2016, 08:32 PM
#584
I personally think that all makes have something to offer. This is what I use.
11-07-2016, 07:14 PM
#585
When I first bought the RV I could move it by hand. After a couple of thousand miles I could move it if it was not in the sun too long as it was cold. Awhile later I could not budge it at all. Last year I broke it down, cleaned all the rust and welding slag from it, re lubed the pin & bearing surface along with the friction plate as per the maintenance instructions. Today I can still move it with some effort. I generally push it under the overhang when camping or parked. I'm 5'8" 170# and 70 yrs old and I still can move it. I'll more than likely break it down again in the spring.
Joe & Beverly
2014 8289WS lifted
11-07-2016, 07:22 PM
#586
The Hensley BD3 that I have is rated at 18K gross trailer and 3,500 # pin weight. The TS3 is rated at 25K gross trailer and 4,500 pin. They are expensive but worth every penny, you get what you pay for. I've had my BD3 for over five years.
Joe & Beverly
2014 8289WS lifted
11-07-2016, 08:42 PM
#587
Originally Posted by head gamez
I realize that. I happily tow my 'Piper with my 2500HD despite many saying I am sure to crash, burn, and ruin the vacation of everyone within a 300 mile radius on the road.
I'm not a an officer on the WP force. I am a rational thinking Engineer that feels comfortable and confident with my towing setup.
Attachment 124580
2016 Sandpiper 376BHOK
2500HD Chevrolet
Love this!!! I feel the same way. Some said that I could not / should not run with my current setup. Have traveled approximately 5300 miles on 4 trips. I love the setup and could not be happier with how everything performs. I would never tell anyone else they should or should not run with a setup similar to mine. All I will say is I am very satisfied with the way I travel.
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
12-09-2016, 09:37 AM
#588
Looks like I'm in the same boat as you two.
....btw, I am also in N.TX just west of DFW.
2017 Brookstone 395RL
2019 Ford F350 DRW w/Demco Hijacker Autoslide (carryover from my previous SB truck).
12-09-2016, 12:07 PM
#589
Myrtle Beach, SC Thanksgiving 2016
2014 Forest River Wildwood Heritage Glen 272RLS pulled with 2014 Ford F150 Lariat Ecoboost with Max Tow Package
12-09-2016, 04:54 PM
#590
PhoneDude
You used to pull that with a Tundra right? I am curious, how long is your short bed? I see you are still using the Reese revolution? The reason I am asking, trading in my Tundra for a 6 1/2 foot bed 2016 GMC 2500 Duramax, on Monday. i was trying to figure out if I still need my Reese revolution..
2018 Jayco Eagle 355MBQS, Andersen Ultimate Hitch
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
12-09-2016, 04:57 PM
#591
Originally Posted by Resurrected1
Nice rig, getting the same exact truck, even the same color, on Monday. You like it?
12-10-2016, 07:40 AM
#592
So far, so good. With the cap design, I'm not sure that I need the Demco autoslider, but that (combined w/the Trail-Air pin) is pretty smooth. Granted, I don't really have a basis for comparison. I'm judging that based on my initial fears -vs- reality. It wasn't near as bad as I had psyched myself up for.....
The truck pulls, IMO, well. You, definitely, know that the trailer is back there, but it's not overwhelming. The truck, itself, has a smooth ride....quiet, powerful, and the creature comforts are nice. Overall, I am very happy. My one regret is that I didnt get the Denali 3500HD DRW....meh..... ......Im actually still thinking about giving this one to the wife and trading her SUV in on one.
12-11-2016, 07:18 PM
#593
My 1500 Chevy Silverado tows my 272RL just fine. No complaints
12-13-2016, 08:20 PM
#594
I use to tow my 30ft v lite with a 2006 Chevy Avalanche 1500 but it wasn't really big enough to tow it long distance. Switch last month to a 2016 Ford F250 6.2 l 3:73 rear end. Haven't got to tow with it yet but come spring it will get it's chance. So far love the Mirrors and backup camera set up definitely going to be easier to hook up. A lot stiffer ride going from rear coil springs to Heavier leaf springs so there should be less bounce when towing. Gong from a 5.3l 4speed to a 6.2l 6 speed should be an improvement. All in, it should do a lot better and I should be able to go a lot farther than I did.
Think about things before you do them make life easier not harder.
12-13-2016, 08:35 PM
#595
You are gonna like the difference. I just upgraded from a F150 and wow! Night and day difference. MPG is not the best but that engine goes when you step on it.
FYI, Keep your tailgate locked. With the camera it is a high theft item. Only takes a minute to remove it.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
12-13-2016, 09:42 PM
#596
12-15-2016, 09:12 PM
#597
My 2016 Jeep Cherokee High-Altitude Limited 3.2 4 x 4 with AD II tows our 2017 Forest River Rockwood Mini Lite 1905S with no problems to report to date.
2017 Forest River Rockwood MiniLite 1905
2016 Jeep Cherokee High Altitude Limited
Thanking the ONE above for the great life here below...
12-15-2016, 10:01 PM
#598
2013 VW Tiguan AWD (2L Turbo - 200hp/207 Torque) easily and safely tows our FR Rockwood Freedom 1940 PUP.
01-16-2017, 01:33 PM
#599
my new to me TV 2015 Silverado
2017 Micro Lite 21FBRS (sold)
2019 GMC Sierra 2500 HD extra cab Z71
looking for the perfect 5er over the winter
01-16-2017, 02:10 PM
#600
Originally Posted by dustman_stx
…..hundred thousand!
What size motor in your F150??
