10-20-2021, 02:18 PM
What weight distribution hitch do you use?
What weight distribution hitch do you use and why?
10-20-2021, 02:27 PM
Anderson, easy, clean, quiet and better ride than the traditional hitch originally on the trailer.
10-20-2021, 02:48 PM
Equalizer. Easy to set up and hook and unhook and works great towing. Great product for the price point.
10-20-2021, 02:50 PM
x2!
I tried one on my 2019 2608bs and it did not control sway well. Even my wife noticed it from the passenger seat. I replaced it with the Curt TruTrack. It works well but, you have to grease it every time you use it and the grease gets all over everything. After driving for a few hours, grease is forced out of the hitch and it ends up on the breakaway cable and 7 way cord.
I had high hopes for the Anderson but, it was not an enjoyable experience towing with it.
I am thinking about trying the Equal-i-zer hitch.
10-20-2021, 03:01 PM
Equalizer with my 2906ws and 3/4 ton Ram. Simple and it works..
10-20-2021, 03:05 PM
Equalizer(tm). One (1) trailer; three (3) tow vehicles; seventeen (17) seasons; one (1) Equalizer
But no WDH will work well unless set up properly and this requires it doing it yourself after the camper is loaded in "full camping" configuration including freshwater. Simple albeit often tedious work as it's much trial and error before it's set right. Setup when empty will just get you home.
-- Chuck
10-20-2021, 03:10 PM
The proper tension on the chains is important and helps. We never really had sway problems, just bouncing rough ride with the conventional hitch.
10-20-2021, 03:59 PM
X4!!
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
10-20-2021, 04:15 PM
I use Reese and have for decades, they work well for me.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
10-20-2021, 04:54 PM
Part-Time Campground Host
X10000. Works great with our 2902WS for over 30,000 miles!
Craig & Cath
Days camped since 2015(retirement): 1680
10-20-2021, 05:03 PM
What is the model number of your trailer and what do you tow it with?
10-20-2021, 05:26 PM
RiderBloke
I have a Grey Wolf 26RR usually loaded fairly full as we are fulltimers and have a 600lb motorcycle. We started out with and used for several years an equalizer hitch but I grew tired of the grease and the weight. I decided to try the Anderson and love it. I think the anti-sway may depend on how much weight is on the ball but we have had no problem with that. It has a couple of quirks but they are easy to get used to.
Retired Intentional Interim Minister
Saginaw Valley BMW Riders
BMW Riders of Tampa Bay
Habitat Care-a-Vanner
10-20-2021, 05:34 PM
I use the Anderson and would never go back to the spring bar type.
2016 Mini-Lite 1905
2016 Ram 1500 QC 5.7 Hemi
10-20-2021, 05:36 PM
I am using the Husky Centerline TS hitch for my Flagstaff 29KSWS. It is WD and sway control hitch. Has done a good job for 4 years now. TT is about 8600 lbs. loaded and right at 1000 lbs. tongue weight.
A lot depends on the trailer loaded weight and tongue weight when trying to pick out proper hitch. Not knowing yours, you will get a lot of different suggestions.
Happy camping.
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
10-20-2021, 05:40 PM
Coachman Cascade 25RKS, I think it's 2003. TV is a 2011 Ram 1500 2wd with 5.7
10-20-2021, 05:51 PM
ysidive
Equalizer hitch towing a coachmen 281 rlds with a 2018 chevy silverado 2500 hd. Diesel... Equalizer works great and the anti sway is the best...
2018 Duramax 2500 LTZ
Freedom Express 281rlds
Days Camping 2021 46 Days
Days Camping 2022 Not Enough
10-20-2021, 05:56 PM
Equalizer. Easy set-up, does what it is supposed to and addressed all the weaknesses i found using the chain-style WDH and friction bar anti-sway. A little noisy, but worth it for the little time you hear it. I installed the pads, but haven't been on a trip since putting them on. Their Customer Support is excellent. I had a few questions, and someone got right back to me with the answers.
2021 MiniLite 2513s SOLD
2-190w solar
2020 Ram 1500 Laramie 5.7 Hemi e-Torque 3.92
1940 Chevy Special Deluxe
1946 Aeronca 7AC Champion
10-20-2021, 06:09 PM
Equalizer here also. Started with my first trailer 30 years ago and still using it 4 trailers later. Easy to hook up, no problems ever encountered except for a broken pin holding the sway bar to the hitch. Luckily didn't lose the sway arm.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
10-20-2021, 07:08 PM
I have moved my Andersen from a 2109s to a 2205s, and today to my new Cougar 26RBS. Great hitch IMHO.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
