Originally Posted by James Jake
Hey Folks
Its me again A couple of things I would like to report in on since you all were kind enough to advise.
Well, I decided to remove the old dead batteries and put the new ones in and of course usually that is a quick job but its still 2020
I called around and 12v AGM batteries
I did not check the voltage on my new batteries when I got them so they could have been completely drained, again I dont know.
If they were even almost drained how long would it take for my 100W solar panel with a 30A controller to recharge them to an acceptable voltage?
Facts I do know - I measured by output from my solar panel and it was about 13.8V
I dont want to take anything for granted, here.
These are deep cycle batteries?
Are they maintenance free or can you add water?
If you can add water, check the level.
Can you verify that the correct leads are connected to the positive and negative posts?
Did you wire the batteries in Parallel? + to + and - to -
you should connect a regular volt meter to the batteries to check the voltage. set it on volts NEVER OHMS and set it on 12v.
A test light only checks available current.
When charging dead batteries, if they have been depleted or discharged, they take extra time and may need more than 13 to shock them back to live. Some larger chargers have quick charge settings. they may have a setting for 40 volts for example. Shop models are common.
Secondly, batteries consume more voltage in the beginning and less and less as the battery fills up. Many battery chargers have 2 or 3 stages and some have an automatic setting that reduces the charge going to the battery. its best to charge them separately. That way if you have a dead cell, it will more clearly show up in the results.
I had 2 12volt wired for my 24 volt minkota. I also bought a second charger that was not as beefy as the first and its always been a dissappointment. So I shock the battery and then use a weaker charger to finish it. I had a week usually between fishing trips.
I dont think some high powered shop charger is needed.
Deep cycle are purposely made for drastic swings of voltage. Car batteries are injured by draining them.
If you need to buy a volt meter, the same basic features are contained in most units. no need to spend more than 30 bucks. If you are not doing home electrical panels etc, dont pay for it.
