Hi, does anyone know where the booster is on the 3050 model? It is not on the plate that the front tv plugs into. The tv switchbox is in the cabinet above the couch and there is no plate there either....all wiring comes through the cabinet and is hooked to the box.
Sorry but I am trying to figure out this system and it is very confusing and frustrating, Paul
I have a 2017 3050s. The booster button is located inside a cabinet just behind the passenger seat and below the radio. There's a 110v outlet and the button is on it's plate. Isn't anywhere near the TV....
Thanks guys,
There is nothing on the "cigarette lighter" outlet cover that the tv plugs into.
Also, there is no outlet in the cabinet by the switchbox.
I don't have a radio in a cabinet behind the passenger seat?? Where exactly do you mean?
Thanks so much, Paul
I have a 2014 Lexington which has a push button switch panel to change the input on 3 TVS (maybe 4) . There are four ( I think) push buttons for each TV. Antenna, Cable, DVD, aux. The booster is built into this switch and turns the booster off and on depending on which TV if any is receiving input from the antenna. Yours maybe the same system.
2014 Lexington GTS 300
2012 Jeep Liberty Toad
Do you have an over-cab bunk or entertainment system? My '16 3050 has the entertainment system, the booster switch is in the right cabinet, left wall, on the far side of the 12V plug.....plate down low, hard to see, have to feel for it...
2018 Georgetown 378 XL
Loved her, listed her, sold her
Queen bed over cab. The cabinet where the booster is is located on passenger side first cabinet behind passenger seat near ceiling. We also have the entertainment system TV in overhead and outside RV with stereo inside and out dvd etc etc etc.
Thanks guys,
I have the bunk over the cab. The power outlet for the front TV is in the bunk area just above the drivers seat. The outlet has the 12V connection and the coax cable connection but no booster button??
I have a 2015 3050s. I have two buttons that need to be pushed. The first is in the 12 volt outlet the tv is plugged in to. It is very difficult to see, easier to feel for it on the far side of the plate (nothing is ever easy). I was only able to see it by getting into the overhead bunk and used a flashlight on the wall plate. The second button is on the antenna directional adjustment knob plate on the ceiling by the door.
