Old 03-15-2018, 01:37 PM   #1
2017 3051 Forester - Door Hinge
Hi again! Our RV has a bar on the door (door entering the living area). The bar doesn't allow the door to open all the way. I can remove the bar, but then we need a door catch. Hubby doesn't want to drill into the side of the RV. Does anyone have recommendations? The pic is one that I got off the internet with a latch, but every latch I see, we would have to drill into the side of the RV. Any recommendations/suggestions is appreciated. TYIA
~2018 Forester 3051
~2014 Surveyor 240SP
~Some other trailer, but was like 8 years ago and don't remember what it was.
nvrsaynvr is offline   Reply With Quote
Old 03-15-2018, 06:24 PM   #2
RedLdr1's Avatar
If you don't want to drill I'd use 3M Bodyside Molding Tape. It holds very well in automotive applications. Just clean everything really well with rubbing alcohol before applying the tape. I've never had the tape fail, and I've used it for years, but if the wind really grabs your door it might pull off the tape.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
RedLdr1 is offline   Reply With Quote
Old 03-16-2018, 10:58 AM   #3
My 2016 3051 has a flexible rod door holder. It works really well when the wind is blowing
radman is offline   Reply With Quote
Old 03-16-2018, 12:58 PM   #4
Thanks Redldr1.
Radman ~ What is a flexible rod door holder?
The bar attached to our door is a shock/strut (??) and it won't allow the door to open all the way.
~2018 Forester 3051
Old 03-17-2018, 02:04 PM   #5
It is the door stopper with a plastic T shaped rod that fits in a slot on the door.
Old 03-28-2018, 09:10 AM   #6
KJcachers's Avatar
The new 3051’s don’t let the door open all the way and there is no door catch on the outside of the RV? Why do they keep changing things out that worked fine?
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 03-28-2018, 09:22 AM   #7
Nvrsaynvr and radman are talking about tow different things, Nvrsaynvr has a piston preventing the door from going 180 degrees. I've asked thses 2 questions on another thread but got no answer. Is the anything on the side of the coach to prevent the door form laying back flat against the coach? Will the hinges allow the door to go 180 degrees if the piston is removed from the door?
Old 03-28-2018, 09:24 AM   #8
Originally Posted by nvrsaynvr View Post
Thanks Redldr1.
A picture of YOUR coach and YOUR door rod would be helpful.
Old 03-28-2018, 09:27 AM   #9
WHY? What is the obstruction if the piston was removed? Design of the hinges? Something on the side? Window? Hood Vent?
Old 03-28-2018, 09:33 AM   #10
KJcachers's Avatar
That’s my point. My 2015 3051 does not have a piston and my door swings all the way open and I have the catch on the outside wall. Why did they change this? Perhaps the y had 2 different style doors depending on the model and wanted to reduce inventory and carry only the one?
Jason and Karen
2015 Forester 3051S
Old 03-28-2018, 09:37 AM   #11
The door is always in the way when it doesn't open all the way. When we sit the chairs under the awning we have to work around the door because the door stays open right in the middle of the chairs. Also if we have people watching tv outside, we have to shut the door, because when it stays open, it blocks the view of the tv for the people who are sitting near the middle of the coach. What a dumb design. If the rod was taken off, yes, the door would open flat against the rig. We basically have to keep the door closed if we want to use the outdoor space under the awning. There would be no issues if the piston was removed, except that there is no door catch on the wall of the rig. That was My original question - for suggestions on a door latch catch that we don't have to drill. My rig is in storage far away, but I will take pics next time I'm up there.
~2018 Forester 3051
Old 03-28-2018, 09:48 AM   #12
the left side of the large window appears to be an emergency exit from pictures of the interior I have seen. I know it sounds stupid..... BUT.....And this is lawyer speak here...... A door latched to the outside would block the emergency exit. Don't shoot the messenger.
Old 03-28-2018, 02:54 PM   #13
Several other 2017 3051 - doors open all the way flush. I have seen them in person. The third pic that has the door open (half way), (that's not my set up), but I was just posting as an example that the door doesn't open all the way flush. I think I will just go with the 3M idea for now. The first pic shows the door latch under the window, ours doesn't have this. The second pic is what my rig looks like, less the door opening all the way.
ID:	166474   Click image for larger version
~2018 Forester 3051
Old 03-29-2018, 07:50 AM   #14
The third vehicle is not the same model and the door only opens halfway because of the awning arms which would prevent the door from opening all the way when the awning is down. This is the same as my 3011.
newRVer is offline   Reply With Quote
Old 03-29-2018, 07:57 AM   #15
Yep, as i explained, that isn't the same model. I only posted it as an example to show how far my door opens.
~2018 Forester 3051
door, forester, 305
