Originally Posted by s1njin
As in the chassis is a workhorse? Beast? Stout/reliable?
The 4500 is pretty strong.
The rear spring stack is way overkill for these short rigs.
You could throw the toad on the roof and be ok.
I hang about 500 lbs off the back and the rig rides better.
Front lower a/arms look kinda weak- nothing else. (alum).
These are made as 200k plus delivery vans.
I would still recommend doing the front alignment to add max caster, front shocks and a steer-straight stabilize. Worked wonders for my handling.
And I get 10.5 -11 mpg not towing- just the bikes.
I usually manually shift the tranny to keep it in the torque band with my throttle . Unless it's really flat. I love the 6spd tranny.
