Old 08-29-2024, 02:52 PM   #1
D9C9's Avatar
24 ½' Sunseeker: Mattress with round corners
Does anyone know where to find a queen size mattress that has rounded corner I think they have a 10" radius and I would prefer memory foam. delivery in Florida. The one I got with my Sunseeker I have slept on since February 25th 2024 so it's not old but is sagging in the middle about 3". It was made by Solaris Sleep company of Ohio.
Full Time and not sure where I’m going but know where I’ve been.
24 1/2 foot Forrest River Sunseeker LE 2350 2024.
Ford E350 chassis no solar and running on a Chins 290ah lifepo4 battery.
Lectric Xpeak tow vehicle for short runs.
D9C9 is offline   Reply With Quote
Old 08-29-2024, 03:16 PM   #2
RedLdr1's Avatar
What model number is your Sunseeker and is the mattress on a slide out?
2024 Sunseeker 2150SLEF on a 2025 Ford E-350 chassis with "Godzilla" 7.3L and 6 speed automatic transmission. "Trekker" Cap, Solar, Suburban IW-60 On-Demand Water Heater, All MaxxAir Fans, Progressive EMS-HW30C, Pacific Dually "Hub Caps".
TOAD: 2024 Ford Bronco Badlands, 2 Door, 2.7L EcoBoost, 10 Speed Automatic, 334A Luxury Package, Leather, Blue Ox and RVi Flat Tow Equipment.
RedLdr1 is offline   Reply With Quote
Old 08-29-2024, 03:19 PM   #3
D9C9's Avatar
It's a 2350LE.
No Slide, basically a mattress in a box with an open end.
I Forgot it's 80" X 60".
Old 08-29-2024, 03:31 PM   #4
RedLdr1's Avatar
Okay, that is the same basic floor plan as our unit without the slide out. The FR supplied mattress in ours is just a regular size (60X80 inch) Queen mattress. Any mattress store should be able to provide a mattress. I used a local mattress company, The Original Mattress Factory, to replace the regular queen mattress in our previous RV. They delivered the new mattress to the storage lot, installed it, and then hauled off the old mattress.
The only "gotcha" I know of is to watch the overall thickness so it doesn't interfere with your side window emergency exit function.
Old 08-29-2024, 04:34 PM   #5
D9C9's Avatar
The only problem is that the corners are normally square and I need rounded corners with about a 10" radius.
Old 08-29-2024, 05:10 PM   #6
RedLdr1's Avatar
The mattress in our Sunseeker is a standard rectangular mattress with rounded corners. The wood bed base is cut to a radius,at the right lower corner, but our mattress isn't, it just hangs over the base a couple inches on that corner.
Old 08-29-2024, 05:34 PM   #7
D9C9's Avatar
Does the little bit extra of the corners take away too much room? Or do you just get used to it. Also does it fit in the corners near the windows and walls?
Old 08-29-2024, 07:11 PM   #8
Why do you need a rounded corner? Just because the original was? I think any local mattress company could make what you want but that corner might be expensive. We have the same model (in Forrester trim) and I don’t think a square corner would hurt much of anything.
2023 Forester 2351LE/2022 Chevrolet Express 3500
phalexander is offline   Reply With Quote
Old 08-29-2024, 07:40 PM   #9
You probably need a custom mattress maker to make one with an exact fit.
You could also check with your rv dealer's service department to see what's available to order.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 08-29-2024, 08:06 PM   #10
D9C9's Avatar
Thumbs up
No I thought I would I'm going to order one from Costco.
Thanks so much for all your input and quick responses.
Old 08-30-2024, 09:39 AM   #11
RedLdr1's Avatar
No, it fits well. The only issue is with having walls on three corners it can be a bear to put on the bottom sheet. But that would be the same with any mattress. We use deep pocket sheets to make it a bit easier.
Old 08-30-2024, 10:19 AM   #12
We use a queen size Beddys to make making a corner bed rasier
Old 08-30-2024, 11:49 AM   #13
D9C9's Avatar
OKay Great thanks for all the input. This weekend might be a good weekend Labor Day always seems to be the weekend holiday to buy a mattress.
I use a Kingsize flat sheet for the bottom and I have a very wide putty knife that I use to tuck in the sheet.
Old 08-30-2024, 02:49 PM   #14
We have a truly oddball "Kinda-King." The factory mattress was wonderful for a year, then turned to mush. Be bought a custom made foam mattress. You can typically dictate:
~ Thickness
~ Dimensions
~ Mattress composition
~ Mattress cover
I think we paid about $500 for ours.
Sources (link)
Jim Moore
SW Colorado - 4-Corners Area
2020 Jayco X213 Rear Slide, 2006 RAM 1500 with Firestone Airbags No WDH
400 watts of solar on the roof & 200 watts of suitcase & 2 x GC2 batteries
Starlink Gen-3 running from a 500 watt pure sinewave inverter
Boondock almost exclusively on the shores of Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 08-31-2024, 04:57 PM   #15
Garrette's Avatar
Several years we order a custom from these folks, rounded corners and very comfortable. We have enjoyed it.
Tip, don’t unbox until the box is on the platform.
https://www.mattressinsider.com/
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 09-12-2024, 06:50 PM   #16
mattress
I have a forester 3051s, I replaced mine with a queen mattress from costco about 3 yrs ago. the best thing ever.
guy goodenough is offline   Reply With Quote
Old 09-12-2024, 06:53 PM   #17
Garrette's Avatar
For our sunseeker with a queen with rounded corners we ordered from here.
Tip. Do not unbox until the box is sitting on the platform.
https://www.mattressinsider.com/rv-mattress-2.html
Old 09-13-2024, 06:21 AM   #18
Try RVMattress.com They can custom make a mattress to any size you want from a basic mattress to a nice Pillowtop. Not sure about the rounded corners. We just bought a new king size Pillowtop mattress for our 5th wheel. Should have done this many years ago.
usraptor is offline   Reply With Quote
Old 09-13-2024, 06:34 PM   #19
Tom48's Avatar
https://go.rvmattress.com/exclusive-...campervankevin
This place specializes in all forms of RV mattress RVMattress.com/CamperVanKevin will get you 30% off this month
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 09-14-2024, 06:04 AM   #20
Papadave's Avatar
If your mattress is similar to mine, just take it out of the zipper mattress cover and use an electric carving knife to radius the corners.
Papadave is offline   Reply With Quote
mattress, sunseeker
