Originally Posted by Babybehemoth
Hi all! I get hot water coming out of my cold water tap whenever I use both the electric and/or gas switches and it doesn’t happen just because the water hose is being heated up by the sun. Is there a way to fix this? There are just two valves in the compartment under the sink. Thanks!
Something in your system is acting as an impromptu mixing valve and forming a loop, allowing hot water into the cold supply. Larry's on to something, too, with the faucet type - does this happen everywhere in your rig (lav, kitchen, outdoor lines)?
Often, this condition is a result of a showerhead handle cutoff being CLOSED and the water knobs being OPENED. It permits the hot and cold water lines to interact, with hot water usually being noticed when water is called for anywhere (else) in the system.
Go through each shower outlet and make sure that the (H) and (C) KNOBS are both turned off, and the handle cutoff is OPENED (such that water under pressure will leak out the showerhead). Make sure to check your outdoor shower (if so equipped).
Test system.
If it's functioning properly now, you can go back and turn the handle cutoff back to CLOSED.
If it's not functioning properly, do a quick valve check everywhere - it doesn't take long. Really important to make sure both valves on the back of the HWH are set to USE mode (with a two valve "U" system - which I believe the OP has - this will be both handles (on either end of the U) turned TOWARD the Hot Water Heater)(with a three valve "H" system - which I do not believe the OP has - this would be both outer valves turned IN LINE with the water lines, and the center valve (on the crossbar of the H) turned to be CLOSED/90°*AGAINST/perpendicular to the water line).
