Old 10-29-2020, 12:14 PM   #1
Dcbenny's Avatar
2800QS GTS additional power supply
After a year and half of putting an extension cord thru the garbage can closet finally got around to installing my permanent additional power supply. Installed the power inlet plug inside the stinky slinky compartment as the hose never fit. Installed a 20Amp breaker box which feeds a 20amp GFCI outlet, and than to 3 outlets, two in kitchen and one in bathroom. DW can now make coffee or use toaster oven with out drawing power from the main 30Amp power, and can use microwave and induction cook top all at same time. the one in bathroom is for the hair dryer again not using the main power has been working great.
ID:	242158   Click image for larger version
ID:	242159   Click image for larger version
ID:	242160   Click image for larger version
ID:	242161   Click image for larger version
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 10-29-2020, 05:23 PM   #2
Ambassador Member
Duckogram's Avatar
Nice work and a very interesting way to address power management on a 30 amp coach. Most units that I have seen with a Marinco add on were done to accommodate a second A/C unit in the bedroom.
Ducky
‘18 Sunseeker 2800QS
Towing Smart
No PM’s.
Old 10-30-2020, 06:50 AM   #3
Dcbenny's Avatar
Thanks Ducky never had a issue with the one 15K AC keeping us comfortable. Cooking was another issue as we don't use the propane stove DW likes induction. That may be next project removing cooktop and adding built-in induction top
Don & Liz B.
2016 GTS 2800QSF
280, gts, power
