Old 04-14-2015, 11:19 AM   #1
2860ds 2014 waterfilter
Anyone have the size or part number to replace on board filter
retired on a mountain is offline   Reply With Quote
Old 04-14-2015, 12:50 PM   #2
Average Joe
MrJoe's Avatar
Attached is what mine has.. CCI-10-CLW housing with a CCI-10-Ca filter.
Name:	2014-01-25 Sunseeker Water Filter 001.jpg
ID:	74248   Click image for larger version
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 04-14-2015, 08:41 PM   #3
Garrette's Avatar
Yep, I concur with the numbers. I ordered from FlowPur. When you order, get the pack of replacement orings, just in case.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 04-15-2015, 10:49 AM   #4
Ok thanks
Old 04-15-2015, 11:49 AM   #5
The filter cartridges are standard 10" ones that you can get most any where ( Wally world, Lowes, Home depot, etc ) in a variety is filter media types and micron sizes.
ATVer is offline   Reply With Quote
Old 04-17-2015, 01:23 AM   #6
I remember seeing some posts on here saying the filter can only be replaced with the FR one because of some mod to the filter housing .. IE standard filters won't work. I also have a 2014 2860DS but haven't replaced the filter.. Can anyone chime in here about it. I remember quite a few peeps were not happy about it..
RON
asparky is offline   Reply With Quote
Old 04-19-2015, 08:45 AM   #7
RON
Maybe the filter housing has been changed after model year 2012 but I have replaced my elements with standard 10 inch filters I got at Lowes and Walmart. I hit some places with bad water last season and needed to replace a couple times.
You just have to be careful and not get too fine (low micron size) a filter or the pressure drop though it will lower the water pressure in the coach. I think the original was 25 or 50 micron which is a bit on the high side but doesn't restrict flow as much as a 10-15 micron.
Old 04-19-2015, 09:37 AM   #8
bubbles's Avatar
RON
You are referring to the filter canister that requires a KW1 type filter. Not the same animal as presented here. Any 10 inch flow thru filter will work in this type canister as previously said..
Old 04-19-2015, 06:53 PM   #9
trdutch's Avatar
We have '14 2860
I replaced with the identical factory filter that I got in the parts Dept of our FR dealer
Campers Inn
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
2014, water
