Old 10-16-2019, 12:44 PM   #1
Pietro Raffaele
Question 2nd television not connected
Hi ... Sunseeker 2020 model 2440DS.
Front television hooked to the Jensen module. All seems fine after figuring out how it works.
Second television in the back ... cannot access the HDMI connections and wondering if it is on a moveable stand. Or ... how to unhook it ... without breaking the wall ... so that I can connect a HDMI element.
Also ... all I can see is a coaxial cable going up behind the tv and (black/white) cable which must be the 12v connection. Do I presume is is an independant tv with only a coaxial connection ?
cg2337 is offline   Reply With Quote
Old 10-17-2019, 05:16 PM   #2
RedLdr1's Avatar
Welcome to the forum. Yes, the rear TV only has a coax connection. Only the front TV has the HDMI connections to the "house" radio / DVD player / entertainment center.
Also both TVs will be linked to the same source, antenna or cable, at the same time. The way they are factory wired you cannot have one TV on cable and the other using the antenna.
Wayne and Christine
2020 Sunseeker MBS 2400Q "The Q" with the Trekker Cap and Metallic Full Body Paint
RedLdr1 is online now   Reply With Quote
Old 10-17-2019, 06:51 PM   #3
Tombsy's Avatar
Not sure you have the same as my Forester but my bedroom tv lifts straight up to release it from the mount.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
sunseeker, television
