3010DS - Bunk Ladder Mounts
Hi All,
On my 2015 3010DS, the bunk ladder can't be used in its current brackets when the visionary sofa is pulled out. The obvious solution (just move the brackets) won't work since the right-hand bracket needs to go too far over and there is nothing solid there for mounting.
I am thinking of designing a new bracket that would solve the problem by being off set from the mounting anchor points. But...just wanted to check if there were any easier solutions before I re-invent the wheel.
