Originally Posted by john mcneely
There are two stars headed bolts in door latch. These studs sometimes cause problems when shutting door. Can I remove them? What is their purpose?
That is a DOT requirement in case of an accident as I recall. It is only for motorhomes. Trailers won't have those latches...no one is riding in while in transit.
There are two ways to do it. Those two bolts, or you can use an automotive rotary latch. Looks like like a car door latch with a bolt on the frame of the door/car and a c shaped latch that rotates around that bolt when the door closes.
