Old 03-07-2019, 02:38 PM   #1
3010DS sunseeker
I do not want to make this long, I slide the rear as I leave or go in to the drive way. Question what to do. Add wheels or does the air bags lift the rear up so that it will not drag. the air bag is for the ride as explained on the side of the unit. Has any other sunseekers had this problem?
ID:	198233   Click image for larger version
ID:	198234   Click image for larger version
SQROOT is offline   Reply With Quote
Old 03-07-2019, 02:46 PM   #2
Shredder's Avatar
someone posted adding wheels to your hitch if you look down the posts. How steep is your driveway in order for it to rub like that wow.
Bob
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 03-07-2019, 02:48 PM   #3
Shredder's Avatar
here is the thread
http://www.forestriverforums.com/for...te-178953.html
Old 03-07-2019, 02:49 PM   #4
A32Deuce's Avatar
I pump my bags to 90psi. There are a lot of driveways out on the road that you will drag on. N & S Carolina have a lot of side streets and store/gas station driveways where you will drag. At 90psi mine still drags but not as bad.
A32Deuce is online now   Reply With Quote
Old 03-07-2019, 03:06 PM   #5
Kanadian Kamper
kenandterry's Avatar
Dragging bottom is not a Sunseeker specific problem. It has to deal with how much overhang your rig has, how much ground clearance you have, and ultimately how steep is the angle of the driveway or road you’re trying to traverse.
Is there anyway for you to change the angle of your drive to the road? Picture the letter “V” and you’re pouring water into the trench to lessen the depth.
Ken and Terry
2018 Sunseeker 2430S sometimes pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 03-07-2019, 03:07 PM   #6
skid plates
Schredder, in the picture the triangle brackets that hang down to protect the connector drag. the putting wheels on the hitch will not work as it is above the skid triangles.
Old 03-07-2019, 03:19 PM   #7
rollers
I am looking at a steel roller like this, but i will need a 4 inches long, cut in half getting a long bolt threaded both ends then the assembled in the botom of the triangle and welding a angle iron over the bolt to hold in place. That is what I am working towards.
Old 03-07-2019, 07:39 PM   #8
Usually Confused Member
emm-dee's Avatar
FWIW, with the MH ready for travel the rear raises 1.9” when I air up from 10 psi to 90 psi
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
saunseeker, sunseeker
