09-22-2020, 06:18 PM
3011ds stereo speakers
There are three zones A B C for the speakers. Both speakers will play on zone A , none on B and only one of two will play on the outside awning. Any ideas. The motorhome is a 2019 3011ds that I just recently purchased. The stereo is Jensen.
09-22-2020, 07:14 PM
Typically Zone A is interior, and Zone B is the awning. I have yet to hear of any unit that was delivered with Zone C active.
If perchance you’re using the Jensen mobile app, be certain that it, as well as the master unit mounted inside the motorhome, do not have the balance shifted to favor only one speaker.
I would be surprised if it was something other than those settings, especially the ones on the mobile app, that are easily skewed by a misplaced finger tap.
Mr Brian
Mr. Brian
2020 Forest River Forester 3011 DSF
09-22-2020, 08:18 PM
I don't know which one it is, A,B, or C, but one of those on mine is a subwoofer.
09-22-2020, 08:24 PM
On the Jensen, zone A is inside, zone B is awning, zone C is probably nowhere.
If you’re getting only one of the two awning speakers, you may want to roll the awning out, look right below the speaker housing inside the rail for the in line spade connectors for the speaker wiring. I looked at that connection recently and envisioned it would be an easy place for the speaker wiring to pull apart.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
09-22-2020, 08:47 PM
I had an aft speaker on the awning fail. Opened it up and found exactly what you described. Reconnected and crimped a little tighter and all is well.
It’s a very easy task...once you get the mud dauber nests cleaned out of some of the screw holes.
BIRDS AREN’T REAL
09-22-2020, 08:50 PM
I can look at that. I assumed that zone c was for the other two speakers inside the coach that don’t work at all. Could there be something fried on the radio?
09-22-2020, 08:54 PM
The A and B zone speakers each have their own volume level control... maybe they have their own balance too. you might check that before removing speakers and/or chasing wiring.
bw
09-22-2020, 09:01 PM
You’ll need a small but long Phillips screwdriver for the six screws on the top of the enclosure. Check the wires running through the awning arm. Let us know the results. Also, check the settings mode on the Jensen to verify the balance is set to zero.
BIRDS AREN’T REAL
09-22-2020, 09:04 PM
A,B and C have their own balance levels.
I have tried on the app and the radio itself. I also tried to play a CD and it never worked .
09-23-2020, 07:11 AM
I have a 2016 3011 with a factory subwoofer. Zone C is for the subwoofer. I have since replaced the factory Jensen subwoofer with a more compact unit that also is also active for the dash unit while driving. I have repurposed the factory Jensen subwoofer to be used outside which has been great for tailgates and also watching movies outside.
2016 3011DS Forester
2014 Honda CRV
Chuck & Lois
09-23-2020, 11:12 AM
[QUOTE=emm-dee;2419273]You’ll need a small but long Phillips screwdriver for the six screws on the top of the enclosure. Check the wires running through the awning arm. Let us know the results. Also, check the settings mode on the Jensen to verify the balance is set to zero.[/QUOTE
Everything has been set to zero. I tried playing DVD/CD and all speakers worked fine, but when I put it on FM or Bluetooth it went back to only 3 speakers working.
09-23-2020, 11:36 AM
[/QUOTE
Everything has been set to zero. I tried playing DVD/CD and all speakers worked fine, but when I put it on FM or Bluetooth it went back to only 3 speakers working.[/QUOTE]
That’s a problem way above my skill level.
BIRDS AREN’T REAL
09-23-2020, 12:05 PM
BTW, have you pressed the reset button to send the unit back to factory defaults?
BIRDS AREN’T REAL
09-23-2020, 01:56 PM
Kanadian Kamper
Mr Brian
I was in behind my Jensen JWM6A once so far. The most obvious thing I noticed was that SOMEONE had cut the Pink and Green pairs of wires (Right and Left speakers C) coming out of the harness, and they were not attached to anything. I didn’t record what the Brown and Orange pairs of wires (Right and Left speakers B) were connected to, but I’m sure they were connected to something. I have no sound from my awning speakers, but I’ll check in the next few days, and report back.
Ken and Terry
09-23-2020, 03:56 PM
Zone C on my 2800QS is the sub-woofer
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
09-23-2020, 05:12 PM
I can get sound out all of my speakers on the tv/cd/dvr but only three of the six work while it is in Bluetooth or radio mode. I called the previous owner and she said she only used it while in tv mode. Sounds like it has never worked correctly.
09-23-2020, 05:44 PM
well that's progress!!! at least all the wiring, speakers, and connections are okay! you just cut the problem in half! now focus on settings in the amp - every program could have its own settings, volume, balance, front/rear balance too ("fader" as some call it), tone, etc...
good luck!
bw
09-24-2020, 01:53 PM
Commercial Member
zone A should play inside speakers and zone b should play outside speakers. zone C shouldn't be hooked up to any speakers. if exterior speaker isn't out it may be loose wire or bad speaker
Kary Katzenberger
Product Manager
Forest River Class C Division
09-25-2020, 09:41 PM
Kanadian Kamper
I verified what Kary has detailed for speaker Zones A, B, and C.
My awning speakers were not working because someone had cut the Orange and Brown wires......the wires for Zone B. The wires looked connected, but in fact, when I removed some black electrical tape, the wires had been cut.
After reconnecting them, I discovered a defective (distorted) awning speaker, so instead of replacing the speaker, someone just disconnected them. It’ll be a replacement project for me over the off-season.
Ken and Terry
09-25-2020, 10:02 PM
Still no luck. I believe the problem is with the unit itself. All speakers work inside and out when you run it through the TV. But it still only works on three when it is on Bluetooth or radio.
