Somebody else might need to know this. Packing up to go on a trip Friday evening, the slide would not go in. Frantically calling RV dealer at 5:30 , they had no idea where an override switch would be (no other 3050s 's on the lot...), no idea if there is a way to get it in manually. They finally called back and said to look under fridge - nothing under there except hot water heater. I looked around and saw a panel under the stove and removed the panel, thank goodness a switch for the slide out. The instructions on the box said to look for blnking lights - none of mine were blinking (maybe because I had completely disconnected power from RV in trying to get slide to work). But there were instructions on the box (... press switch 6 times and hold on the 7th ). A few prayers later and it the slide worked.
Why the slide stopped working is a question - will definitely keep an eye on it.
- Why isn't this switch documented somewhere.
- If I ever get stuck again and this override doesn't work, is there a manual way to get the slide in. The owners manual has something about "manual slide room operation", but it doesn't go into much detail. If all else fails there has to be a way to manually put the slide in.
