Old 04-19-2015, 11:05 AM   #1
3170ds box on cable under drivers seat
i am thinking about buy this unit and it has a ford f450 chassis and under the front seat is a box on a cable ? Anyone know what this is could it be auto levelers?
sunseeker3170ds is offline   Reply With Quote
Old 04-19-2015, 11:30 AM   #2
Citrus County, Fl.
GL1800Rider's Avatar
Yes, it is the auto leveler control. If you order a new unit it should be mounted on the panel as you come in the door.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 04-19-2015, 11:37 AM   #3
Would you know the manufactuerer
It is a 2015 and figured it would have been mounted....it kinda looks like a pedal but i did not pick it up...
Old 04-19-2015, 03:58 PM   #4
Unless the newer models have changed the Big Foot Leveling system control box is stored under the seat. It has a cable to it so you can stand outside while you operate the jacks. It has a full automatic mode but I have found manual mode works better sometimes especially if the campsite is more than a little off level. I have seen some other manufacturers who mount the control box in the step well but IMO that is a very poor design if you ever want to use the manual mode. You need to be able to see the operation of the jacks to properly and safely manipulate the jacks in manual.
ATVer is offline   Reply With Quote
Old 04-19-2015, 05:24 PM   #5
Citrus County, Fl.
Here is a picture of the new location. Picture is not too good but it is located just under the counter extension. I think most people wanted it here as it is a cleaner look and hopefully you can stand outside to operate. I will find out in about 4 weeks.
Name:	3011 BigFoot.jpg
99 Terry 31G
Old 04-19-2015, 08:50 PM   #6
I saw a new unit on the lot this week and they've also modernized the faceplate. I like the new location but I'm hoping it has some kind of lock-out function to protect the control panel from little fingers.
steverkemp is offline   Reply With Quote
Old 04-20-2015, 10:40 AM   #7
Commercial Member
There is a "Power Button". So no LED lights unless the power button is ON. Then you can push the other buttons.
Otherwise, a small snap on cover would work if you're really worried about the little ones.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (Do Not Ask in a PM) so others can benefit from the answers.
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-20-2015, 10:44 AM   #8
Can you power off with the jacks down?
Old 04-20-2015, 10:52 AM   #9
Commercial Member
yep
