Originally Posted by shenry4244
I have a 2017 Forester with E450 engine. I hit a large bump and my cab AC stopping putting out cold air. Heat works. Any ideas to check?
Well... there are plenty of things that "could" go wrong.
Anything from when hitting the "large bump" you put a hole in a part of the A/C system and all the freon escaped to... you jarred a wire loose that controls the compressor clutch... to several other things.
You are going to need to have someone look at the system and eliminate the basics.
At this point, any suggestion is simply a guess.
