Old 05-17-2013, 10:12 PM   #1
A/C Vacuum Lines for V10
I have a 2005 FR 29 V10 with ac vent problems. I had some broken Vacuum line at the access panel on the dash. I repaired them however when I hit 40MPh is goes to default defrost. I rechecked all the line and tested the main line at idle and getting normal vacuum pressure. What else should I check??
bigdog1001 is offline   Reply With Quote
Old 05-18-2013, 05:22 AM   #2
cpaulsen's Avatar
Did you check your vacuum cannister up by the battery under the hod??
cpaulsen is offline   Reply With Quote
Old 05-18-2013, 09:45 AM   #3
Hmm I only see 2 cans on dash none near battery
