05-01-2017, 09:52 PM
Sophomore Campers
Absolutely gutted! Water leak and haven't even camped out yet!
Getting ready to go on our first true camp out this coming weekend. My wife texts me at work to tell me our camper had water on the table. New 2017 we've only had since end of March and already regretting it.
Water appears to have come in from the roof antenna, down the coax, through the jack in the cabinet where it accumulated under and on all of our remotes, then spilled out onto the table.
I don't trust turning on any power right now. The 120v and 12v outlets were wet. Luckily I had the disconnect off so no live power in the unit right now.
2017 Sunseeker 2860DS
05-02-2017, 08:04 AM
Check all the caulking around the antenna mount and where the coax boot enters the roof of your camper. There's also an O ring that might need a little lube. Check out this thread on antenna leaking: http://www.forestriverforums.com/for...eak-38196.html
05-02-2017, 08:10 AM
I had a similar experience with my Hot water tank newbie mistake forgot to take the drain plug out when winterizing it cracked at the weld where the electric relay heater is connected to it and split down see pic I welding friend of mine says it was the weld was bad and it is fixable my dealer says Forester river will not pay for it because water damaged it [IMG]IMG_20170502_092347[/IMG]
Rob & Elizabeth Sweeney
Having fun in our Forester Gump (2015 3051S forester)
05-02-2017, 08:14 AM
X2 on the little rubber boot on the coax. They tend slip up the coax and water will wick down the coax and into the RV. If this is the case, a small amount of Shoe Goo ( available at craft stores) inside the boot will keep it in place. It is easy to remove should you need to do so.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-02-2017, 08:22 AM
Sophomore Campers
What about electrical? I've been running my large dehumidifier in the RV plugged into the house since last night. Humidity got down to 45% from 65% but now back to 65%??! Maybe because it's so cool in there at the moment.
Is this something the warranty should cover for water damage?
We had about 5" of rain this weekend.
05-02-2017, 12:10 PM
MH Noob
Mizzou - I also have a Sunseeker - 3120 to be exact. After reading this forum when I got my rig the first upgrade that I did was to Eternabond every seam on that thing. I know this may not be your issue for the current problem but I highly recommend it for the future. Water is of course the enemy in these things and the factory seal jobs seem to leave alot to be desired. Spend the $140 or so dollars and tape every place on the roof that has dicor on it. You will sleep oh so much better.
05-02-2017, 12:35 PM
Sophomore Campers
I climbed up on the roof. The way they did this it doesn't have a boot. Will post photos later.
05-02-2017, 12:40 PM
leak on new unit
Don't do a thing but take Pics then take the Brand new unit back and demand a new unit they messed up and it will never be right even if they repair the leak not worth the hassle on your part.
2015 Rockwood Roo 233s
2012 Ram 1500 5.7 Hemi
05-02-2017, 12:51 PM
I had something very similar to what you're experiencing. Winegard antenna. Attached to the handle is a hex shaft with an "o" ring which was missing. Replaced the hex shaft and new o ring. Problem solved. If I recall you had to put the antenna up and go topside and remove an "e" clip to get the handle out. Owner's manual I believe states it should get periodic lubrication. You check
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
05-02-2017, 01:06 PM
Sophomore Campers
This is what I found when I climbed on the roof.
Suspicious seal job.
Crack in the antenna
Missing rubber end on the antenna element.
Small holes in seal around base of antenna
05-02-2017, 02:22 PM
I think I would be on the way back to the dealer ASAP! How long did it sit at the Dealer's lot and leak?
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
05-02-2017, 03:46 PM
Take it back to the dealer, this should be on them and Forest River, not you.
05-02-2017, 03:51 PM
Sophomore Campers
No doubt. It just sucks because this is going to cause us to cancel our first planned camp out this weekend and the dealer is an hour drive away.
I've contacted the dealer, sent all the photos. Now it's a matter of finding the time to get it there, have my wife follow me because we aren't set up to tow.
05-02-2017, 03:53 PM
It looks like the ant may have hit something hanging low. I would return it to dealer and send photos to FR rep. If they say they plan to repair it, I would ask them to call you once it has been torn down so you can go to dealer to look at to verify the amount of water damage if any.
TST Tire Monitors
2 100W solar panels
05-02-2017, 05:41 PM
Sophomore Campers
Is there a reasonable alternative to Dicor that I could use to plug the gaps I see around the coax as seen here:
The RV places nearest me are closed already & we have more rain coming in. I wanted to seal it up to at least prevent more damage.
05-02-2017, 08:06 PM
I know earlier you asked about something better than Dicor. But really, Dicor is the thing to use. Just get it in the gap. Whatever you do, don't use silicone.
You could wrap the antenna with a garbage bag or two for now, also. Maybe wrap it with a towel so it doesn't poke through the bag.
Good luck!
2014 Sunseeker 2300 Chevy
05-02-2017, 08:15 PM
Sophomore Campers
Good luck!
I was just looking for something I could get easier than dicor since it's apparently only available at RV places and they're all closed. I wanted to get some and get it on before we get more rain, which is expected to be tomorrow evening. I might could get some around lunch time and go patch it so it has enough time to set up before we get rain, but there's a slight chance of rain at mid-day.
05-02-2017, 08:17 PM
Sophomore Campers
Good luck!
The problem isn't with the antenna. It's with the coax that comes out of the antenna and goes through the roof. I was trying to think if there's a way to maybe put plastic over it and use some tape to try to prevent water from getting into it, but not sure how I could tape it up that would make it less likely to leak.
05-03-2017, 12:16 AM
I use Sikaflex 715. It doesn't get as stiff and create cracks later on.
2020 Grand Design Reflection 240 RL
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
05-03-2017, 04:07 AM
While shopping for TTs in the wet spring months I purposefully stopped after work at local dealers & viewed units in the middle of/just after heavy rains... A new unit, same brand/model as the one we eventually got, leaked water badly... The salesperson verified that all vents, etc. were closed while we both watched a HEAVY stream of water pour down a wall, across the dinette, and out under the slide-out... The salesperson put a work-order in, and I (imagine) they sealed the leak. However, I'm sure someone eventually bought that unit...
NOTE TO OP: IMO there is no way to know how much water entered the RV & how much hidden damage was done while it was traveling to the dealership, sitting in the lot, etc. IMO it would be worth it to pay a professional 3rd party repair service to carefully inspect your unit to make certain there is no unseen lasting damage... IMO the materials used inside RVs are not capable of being exposed to water for more than a few hours before permanent damage is done...
Back to the new/wet TT... This experience led us to buy a mildly used unit, same brand/model, that appeared to have better fit & finish than ANY of the new units on the lot... (Older unit built during the recession vs. the current RV boom...) On the used unit I spent 2 hours looking behind every cubby with a flashlight verifying that the original saw dust (which they always carelessly leave-behind) was still spread-evenly in those areas & not clumped-up like rivers of water had flowed across it...
Before the PDI the dealer included a FREE pressurized leak-test & re-caulking & then we spent 2.5 hours doing a full PDI hooked-up to everything, water up to full pressure, etc. We have camped for the next 3 years without any issues.
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2018- 25
2017- 31; 2016- 36; 2015- 37; 2014- 31
