Old 07-11-2019, 07:55 PM   #1
ScubaSteve71's Avatar
AC issues on 2013 Sunseeker by FR
Anyone else had to replace their A/C yet? It was only showing a 13 degree difference from intake to output. The amperage draw was low too. I never understand why these are closed systems and why you canít add coolant to them. Also the v ent channels were not closed off at the end of the last vent which means a good portion of my air was blowing into my roof at both ends of the coach. Come on FR we can do better than this. I replaced it with a Advent AC system. Hopefully it last longer than the Dometic system that came with it.
ScubaSteve71 is offline   Reply With Quote
Old 07-12-2019, 11:38 AM   #2
SeaDog's Avatar
you already replaced the unit so this is just for information if a unit has a small drop in the delta T (20* being about max drop) across the coil but is till cooling before replacing the unit clean the coils and filter then recheck could save hundreds of dollars
Retired Navy
2016 Flagstaff 26 FKWS
2013, sunseeker
