Old 07-26-2020, 07:57 PM   #1
Add LED for reverse wiring
What would be the best way to tie into reverse or a reverse light to wire in an LED light?
I want it actuated when put in reverse.
There is a wire harness and loom just behind the hitch. Appears to go to the driver tail light.
2019 Forester 3011 DS
2015 Jayflight 28BHBE (sold)
2015 Ram 2500 Megacab 4x4 6.4 L Hemi 4.10 gearing
"Is this a game show?"
sugarray40 is offline   Reply With Quote
Old 07-26-2020, 08:04 PM   #2
Ambassador Member
Duckogram's Avatar
Beep beep backing
If it was me I would not disturb my chassis wiring harness. I would opt for the
trailer wiring connector. The backup lights are the center pin. YMMV
Just Ducky
Towing Smart
No PMs (they are not private anyway)
Posting exclusively in the Forester/Sunseeker section for the amusement of fellow Forester/Sunseeker owners.
Duckogram is online now   Reply With Quote
Old 07-26-2020, 08:15 PM   #3
mescuba4's Avatar
I installed a 3-way switch on the tongue of my camper, just behind the propane tanks. I get power source from the 7-pin harness junction box (Reverse power wire) on the tongue, then another 12v source from my camper battery. So I have the option of Lights on when vehicle in reverse, OFF, then Manual override anytime I want to brighten up the back side of the camper when camping..
mescuba4 is offline   Reply With Quote
Old 07-27-2020, 09:18 PM   #4
Bezzola's Avatar
I went from the fuse panel to 2 switchs in the dash one runs my LED bumper lights and the other runs the 4 LED lights i put on my enclosed
I wish i knew how to add pics
Bezzola is offline   Reply With Quote
Old 07-27-2020, 09:19 PM   #5
Bezzola's Avatar
Old 07-28-2020, 12:17 AM   #6
dbledan's Avatar
You could wire to the reverse pin in the 7way junction box. I would suggest using that as a trigger and use a relay to the battery so you are not pulling large amounts of power through your Tow vehicle for spot lights.
I connected it to a wireless remote instead directly to the TT battery. I keep the keyfob in the truck and just turn it off and on manually.
https://www.amazon.com/dp/B01CCSG2ZY..._Hh7hFbKWT3ERH
I put it all in a dry work box on the tongue. The remote controls the reverse lights, some other lights and the tpms repeater.Click image for larger version
ID:	235021Click image for larger version
dbledan is offline   Reply With Quote
Old 07-28-2020, 12:45 AM   #7
The first issue would be to connect the center pin of the 7 pin connector to the reverse lights of the tow vehicle. That connection is not normally made be default. Then on the trailer, I would have that center pin run to a relay with the secondary side of the relay supplying power from the trailer batteries to your back up LEDs.
NavyLCDR is offline   Reply With Quote
Old 07-28-2020, 07:41 AM   #8
Ambassador Member
Duckogram's Avatar
Originally Posted by Bezzola View Post
Looks like you have the photo posting down. Only question is; What is that white stuff on the ground. Looks scary.
Just Ducky
Towing Smart
Old 07-28-2020, 10:08 AM   #9
Bezzola's Avatar
Poulin from the trees
Old 07-28-2020, 10:14 AM   #10
007matman's Avatar
I put it all in a dry work box on the tongue. The remote controls the reverse lights, some other lights and the tpms repeater.Attachment 235021Attachment 235022
That's a pretty slick solution. I may have to steal your idea!
Thanks for posting.
007matman is offline   Reply With Quote
Old 07-29-2020, 12:50 PM   #11
Nice job. I think the OP is a class C. I'm sure it can be done like you did it.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 07-29-2020, 02:59 PM   #12
dbledan's Avatar
I missed the forum and read the posts about the trailer hitch and went to TT mode in my head. I would still use either a relay if tapping into the chassis reverse or use the remote option.
Many models have a canbus that will detect too high of a load as a short and shut down the lighting circuit. They have put it on most of the high end trims but not sure what they have done to the chassis models.
Old 07-29-2020, 05:01 PM   #13
True, with computers taking over, you need to find other ways to go. relay is a good way to go.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Old 07-30-2020, 12:20 PM   #14
So yeah, the center pin is hot in reverse so I'll tie into the wiring for the trailer connector. Thanks for all the ideas.
Old 08-03-2020, 05:45 PM   #15
Any idea how to pull off a tail light?
Old 08-03-2020, 05:51 PM   #16
Ambassador Member
Duckogram's Avatar
On my last unit they were sealed led units that had nuts
on studs covered with foam on the back.
So what happened to plan A?
Just Ducky
Towing Smart
Old 08-03-2020, 06:05 PM   #17
I was unable to access the wiring harness for the receiver without cutting into it. I figured it would be easier to tie into the reverse light from a tail light. But, i was unable to pop a tail light off to check it.
led, wiring
